Lower radiator support part source.
Brisbane, Australia
Looking to try and source a rust free or even new lower radiator support (part number for lj78 is 53028-60020 and kzj78 is 53028-60021)
In reality these should be identical parts as they are the same frame and front end? Mine is rusted out unfortunately see photos attached. I’m located in Australia if anyone can help or guide me to a solution. I have found a kzj78 lower rad support but will cost me upwards of $430 aud to get it from Japan to Australia and I’m unsure if they are the same part?
Update, the kzj78 lower radiator support is out of production too so no longer available on the website in Japan. Anyone wrecking a lj78 in Aus or New Zealand?
It might be easier to just repair the part you already have, if it isn't too far gone already. Looks like it ought to be a fairly straightforward welding job, especially since its location on the vehicle doesn't require perfect joint fitment.
Unfortunately it seems like it’s rusting from the inside out and it’s starting to rust through around the body mounts, going try repair for the mean time but after a long term solution.
