- Joined
- Oct 4, 2008
- Threads
- 193
- Messages
- 6,211
Well guys, I would like your opinions on cleaning the lower intake plenum.
Mine is really, really nasty! Probably one mm or two of gritty gunk.
Several months ago, I pulled the throttle body and upper intake for cleaning but I decided on not pulling the lower intake due to the wiring harness being threaded through it and the tight tolerances on the bottom bolt on cylinder #6 (worried I can't get a torque wrench in there to properly torque it on reinstall).
I currently have my upper intake plenum off, again, since I pulled the fuel injectors for cleaning & fuel filter replacement prior to installing a supercharger.
I am wondering what your thoughts are on cleaning the lower intake. Can I clean it, scrub it and shop vac out the contents or should I remove it for soaking.
If the general consensus is to remove it, how hard is it to unplug the lower wiring harness and thread it back through the intake to facilitate removal? Since it appears that removing the upper harness involves way more work since it goes right into the firewall.
*Note my harness is not brittle and is in good shape.
Thanks!
Thanks!
