locks on hardtop
Colorado Boy-74-FJ40
I may grow older but I refuse to grow up!
Windsor Colorado
I have a hard top on my 74. I do not have the keys for it. My dad converted from a soft top about 10 years ago and I don't think there were ever any keys. Can I get keys cut from the dealer... locksmith? The numbers adjacent to the keyholes...are they key codes? Don't want to spend a fortune. Anyone been here?
give kurt a call he cut me a few keys for super cheap. the numbers on the cylinders you will need
Number?
Kurt who? My first name also happens to be Kurt. can you PM me his number?
Does he use the same keys that walmart uses. I don't like the keys from walmart because they are longer. Are Kurt's keys the same length as the original TOYOTA. Thanks.
YEA, I had the same problem with keys I found at Home Depot. I bought 2 keys but they were about 3/8 inch to long. I took them home uncut and ground them to the same lenght and end taper as the stock keys. The clerk wrote on the ticket that I would bring the keys back in to have the teeth cut later. Problem solved!
I'm not sure about a 74, but I had a hard time finding keys for my 71. On the FAQs here - https://forum.ih8mud.com/showthread.php?t=65739 - Poser lists a company that stocks old keys - Key men. The link is http://www.key-men.com/. I ordered some keys from them, and they were pretty cheap. I just had to cut them when I got them in. Also, I ordered a new lock for my back hatch. Those are still available from Toyota, and you get new keys with them.
Good luck!
FF LC FREAK
I also have a 71 FJ40. Did your new lock for the back hatch match the pattern for your door/ignition key (will the one key fit into both lock cylinders, even if the cylinders do not have the tumblers set to match)? On mine I have to use two different keys since the keys are patterned completely different. I have to find the door key to open the drivers door, then find a different key to open the hatch (annoying!!!). I would like to have them both keyed alike.
No, the keys don't match. I also have two keys - one for the ignition/ door lock and one for the back hatch. I didn't bother trying to find a matching lock. I have a Ford Bronco for a DD that also uses two different keys for the back window and for the ignition. So, I'm kind of used to it. It doesn't really bother me.
:cheers:
