Lockers?
Colorado
Hello...new here, tried to find the exact answer to my question and couldn't, so here goes:
Are lockers desirable, if so, why? I'm looking at buying an 80 series (they are in the price range that I can afford comfortably) as second car, driven on weekends, etc. I see some out there that have 'em and some don't. What do they do for you and are they a desirable option?
Thanks for your input.
Mac
Look in the 80 series faq (sticky thread, top of 80 series forum), there is a writeup about lockers in the "general" section, IIRC.
EDIT: Here is the diff lock link: http://www.lcool.org/technical/diffs/diffs.html , there is more info in the faq, about differentials...
The answer to your question has to do with what you intend to use the rig for. For daily driving and weekend adventures, skiing, etc., lockers are not necessary, and if used improperly, even dangerous. If you intend to wheel a lot, they are still not required but sure make the 80 more capable. If you intend to crawl rocks, they are most necessary. For the stuff I do, the only time I lock up is in the sand dunes and on one particular muddy driftboat launch.
If you take your time searching you can usually land one with lockers without spending additional $$$, as most owners don't have a clue what they are. That being said, I'd rather have one with than without. Having locked and non-locked vehicles in the past, I was adamant about finding a truck equipped with them.
Good luck with your search.
