Lockers question - Bypass CDL sensor?
Hamilton, MT
Hi All -
I am new to the forum. Lots of great info on here. I just bought a 1994 FJ 80 with 250k miles. Its never been offroaded so is in pretty good shape. Of course it came with difflockers that wont engage. I have traced the problem to a bad CDL sensor on top of the transfer case. When i jumper bypass the sensor the FF and RR actuators work.
This and the fact that manual says diff lock shuts off at >5 mph got me thinking, has anyone tried simply bypassing the CDL sensor? This would allow using the front and rear diff lockers in high range. thanks
The diff locks can only be engaged below 5mph, but they'll stay engaged above that.
Locked axles won't be very useful with an open CDL.
And welcome to MUD.
Installing a CDL switch in the dash accomplishes the same thing. The wiring for the switch is hanging behind the dash. This will allow you to lock and unlock the CDL in high range.
The "pin 7" mod will allow running in low range with CDL unlocked. Cheers
Just to be clear, even with pin 7 mod you'll need to get your CDL indicator switch working to have axle diff locks unless you do bypass it.
If you do bypass (jumper) the cdl indicator switch, your CDL and ABS dash lights will stay on and ABS will be disabled. It would be possible to trick just the diff lock ECU into thinking the cdl is locked without turning on the light or disabling ABS (cut the pink/black wire on pin 15 of the axle diff lock ecu and apply ground to pin 15, tape or cover the other part of the pink/black wire going into the dash harness). Even then you won't be able to lock the axles above 5mph because that ECU gets its own speed signal.
Just get the correct (EDIT) CDL INDICATOR switch. Can be sourced used out of parts yards.. Commonly used for reverse lighting on manual early-90s corollas.
Getting that working plus doing the pin7 mod gives you lots of options. Diff locked or not in high or low, and enables axle locks in either high or low as well.
'93/'94 may have a curved factory CDL switch in the dash already
Thanks for the responses! This week I will be starting on the CDs switch and 7 pin. I need to replace the cdl sensor too because mine is broken at the top where wire connector attaches.
The sensor looks to be a tight fit for getting a wrench in there. Anyone done this that can say what wrench worked?
1 inch worked for me. It was pretty easy.
Lowered the transmission crossmember about 2 inches and used a big crescent. Didn't seem like it'd work but it did..
Happy to report that after installing a new position indicator switch all 3 lockers work great! It took a 1 1/16" wrench and that was the easy part. Repairing the corroded blade connectors took some finesse .
Thanks all for your help!
