Locker wiring pic....
North GA
Can't get my front or rear lockers to engage (lights blinking). PO since '99 said he wasn't sure if they've ever been used (it was actually his son). Wiring doesn't look damaged which makes me think they're just frozen up. Should I unhook the connectors and clean them? Do these wires control front and rear?
I think we're going to need a fuzzier less descriptive picture :P
Done all the other suggestions first? I doubt it is the connector but won't hurt to try and takes 30 sec. I'd go do more figure 8s
More then likely they are just gummed up from none use, do as the other members have said. Take it out, turn the magic dial on your dash, then drive it in figure 8's in THE DIRT, NEVER use them while driving on pavement. After you try that if they still won't engage we will help you trouble shot it from there.
I have two lights flashing when in 4L and my dial turned all the way. Normally there are three....my center light is missing correct? And I've been doing figure 8's on pavement; this has worked in the past to at least get them to engage but not this time. 4L works but that light is missing as well.
When you put the vehicle into 4 low that should activate the center diff lock. The CDL needs to function and lock before the system will let the front and rear lockers engage. This was most of my problems with my factory front and rear lockers, my CDL switch was dirty and the CDL actuator was slow. After cleaning out all the switch connectors on the t-case and activating the CDL a few times it is working like it should and the front and rear lockers are starting to lock quicker as well. So the main thing is get your CDL working then see if you need to dig into the axle locker actuators.
I have a '97 and I don't have a center diff switch only. So when I put it in 4L it should activate automatically as stated. So it seems I may be in 4L without my center diff locking? Hence the front and rear not locking either. The third yellow light does not come on when I shift into 4L.
Yes, without adding a CDL switch and doing the pin 7 mod putting your vehicle into 4 low is the only way to activate the CDL. I would start by cleaning the connector at the CDL position switch on the transfercase. If that doesn't work I would jump the body harness side of the position switch and see if the CDL light comes on solid in the dash. If it does then you can try removing the position switch and giving it a good inside and out cleaning and see if that gets the CDL to work when going into 4 low. If it still doesn't want to work I'd get a new CDL position switch and see what happens before I took anything else apart. I got lucky with my first 80 series and my current one and only had to clean the CDL position switch connector and put it back together with some dielectric grease to prevent future corrosion and water intrusion.
Mine had good wiring to the light, good connectors to the CDL switch, but the switch refused to work, so no light on dash and no diff locks.
I read on this board about it switching too little current to "self-clean" the contacts inside, which is what usually causes them to stop working. Same thread recommends cleaning the contacts by jumping it for a VERY short time with a 9V battery.
I removed the switch, rigged up a couple wires to a 9V and just barely tapped the contacts, and reinstalled. Didn't work.
Used the truck battery and tapped the contacts for just an instant.. now the switch works perfectly.
I'd try and use as little voltage/current as possible, only moving up once you determine that as little as possible won't work.
I always suggest putting the truck on stands and turning one wheel to test lockers. You don't need the vehicle to be running. Just the key turned to on and then go through your testing procedure. This also allows you to hear the motors whirling.
I just went through this in my 93. I started with the front locker - pulled the motor apart completely (it was very stiff) and upon testing/research found out that, as others have stated here, that unless your CDL activates the f/r locker computer will not attempt to lock the front nor rear.
Get the CDL to work - could be as simple as the switch isn't registering. I tried to clean my old switch and it was sporadic at best. I replaced mine - found that a 2nd Gen MR2 reverse switch was identical. Was about $18 via Amazon Prime.
I had the same problem when I bought my truck a couple of years ago. One of the Mud members was underneath tapping the actuator as I engaged/disengaged it. Between this and the figure 8's, it started working again after who knows how many years or decades of inactivity. Remember, slow figure 8's on dirt.
I know this should be simple but is there a trick to getting to the CDL position switch? My CDL only engages once in a while so I wanted to try to clean up the contacts but I can't get the switch unplugged. The breather hose seems to be very inconveniently located and I can't get the male/female ends of the plugs to separate. I've read every available thread on CDL issues and everyone seems to breeze past accessing the plug to check it but I can't seem to get it.
What switch are you attempting to access? Looking at the NCF info starting in post #45, CDL Actuator Fun there are two switches relevant to the CDL. The 4 low position switch, senses the 4 low shift and turns on the CDL system, is on the rear of the transfer. The CDL indicator switch confirms CDL activation, turns on the dash light, off ABS and activates the axle lockers (if equipped).
If inop, both can be relatively inexpensively replaced. From your favorite parts store order a reverse light switch for a 2000 Tacoma with a 5spd trans.
I've already replaced in indicator switch, and that didn't solve the CDL issue. The plug I'm attempting to clean is not any of the switch's but comes from the wires that come out of the top of the actuator, and tie into the 4l switch. It is hooked on to the top/rear of the actuator. It's just a male to female plug and from what I understand it is how you diagnose the actuator.
