Not sure. Including all of my over engineering thought processes a ridiculous amount of time. Probably between 50 - 100 hours.
So after that work of art, what are you gonna do up front?
Nice representing the SoCal 80's!
The only thing I can see that may become a concern is the length of the swing out arm. That is some major strain on the spindle. I notice how that can become a problem on my Hanna. I have to re-tighten the Crown nut every so often and replace the cotter pin.
Now get back to work on mine!
So after that work of art, what are you gonna do up front?![]()
Fuscia or hot pink?![]()
Thanks brother. I am not sure about the rating on Ken's but I am sure his is more than adequate too but Luke's is rated at 3500 lbs so the weight and leverage should be no problem for it. That is unusual that you have had to re-tighten your castle nut. Probably just the bearings pre-load being a little low and as it works it's way into the loades position it is creating some slop. It is impossible for tapered bearings to continually loosen without creating bind in the bearings if the castle nut is cotter pinned properly. Assuming no catastrophic failure of course. I would keep an eye on it but you should see it stop.![]()
(TOOL)
Well then I guess your only downside would be the extra two steps you have to take around that big old swing arm when you are loading up the truck!![]()
Bluetribal,
you must have one of the old bumpers. All of Hanna's new bumpers have significantly larger spindles.
that is odd that the castle nut loosens. I have never had that happen and I remove my 2nd carrier swingout and re-install a few times.
Very Very nice......clean and well thought out. Man do I need one.......if I only had 100 hours
How much does it weigh without the tire or the jack?
How much lower did your truck sit after install?
You have talent!!!! That looks awesome. Which I had the tools to try something like that.
Very nice!
Yer rear tire don't have much wiggle room when it's stuffed....![]()
The "tools"? or the Nuts? lol![]()
I wish I had the tools and the skills to put something like that together. Some day
gotta ask slomo, 17" FJC steelies?
sick a$$ bumper! dayum!
(edit, just saw the sig, lol, those mojaves look like the fjc steelies)
