lights flicker Ampmeter fluctuates
Turn off your turn signals!
Sell that low milage 55 to me and that will solve your problem.
I am having issues with my 69 also but it just blows a fuse and everything goes black, I believe that it is in the hi/lo switch or a bad ground. I tried messing with the on off switch and cannot get it to fail and of course if I run with the lights on in the daylight I have no problems. After reading this board for awhile the other areas are were I'm going to look next.
Perhaps Kip works for the Department of Redundancy Department?
I agree with Skyshark. I had a similar problem and replaced the alt, VR and no effect. I disconnected the ground from the frame and cleaned up all the connections and no more problem. They will dim a little when you stop. I had already replaced the alt with a 55W Duralast ($40) from autozone before I cleaned the ground, so it might have been the two together.
Also check your grounds at the lights themselves.
