Haven't been on Pirate in forever!
What about the Roundeyes kits?
Are you replying to your own post rookie?![]()
i have an old school trucklight led headlight and like the bright cool light. only thing disappointing is that they are d.o.t. lights, so they're not blinding bright
not that i would run anything illegal on the road
i do love the fact that if there are issues, the warranty process is simple, and i can beat it with a hammer and the hammer will bounce back and probably knock me out cold before it damages the "lens" cover.
That is not the conclusion I came to at all. Halogen for the price performance win. The LEDs were not 4x as bright, by any means and the halogens had stock bulbs for the test. Upgrade them to 55w/100w bulbs.
That is a good question about the wiring harness...
Who makes a good headlight harness upgrade for 40s?
I went with this kit, it was easy and works great...my halogens are much brighter and the wiring does not heat up now...a big plus!
http://www.madelectrical.com/catalog/rly-1.shtml
Not affiliated, yada, yada..
Cheers!
Thanks!
that won't be a plug and play harness, that's a relay kit for essentially building your own harness. for plug and play, go to lmc or one of the "restoration" type places. they have plug and play harness for old trucks. just pick a model with 7" round lights
Aren't roundeyes just a housing intended for an incandescent bulb? Or do they have an HID specific setup now?
i used sylvania silver star headlight. plug in and go $50 for both of them
Am I looking up the wrong headlights? I figured they would be a couple hundred but $800?!?
? Is there anybody in this thread that is seriously considering dropping $800 on a set of headlights? More power to you and I would certainly like to know if you get $800 worth of satisfaction out of the difference in performance.Then I looked up JW Speaker 8700 series 7" round headlights and they were $800 per pair!Am I looking up the wrong headlights? I figured they would be a couple hundred but $800?!?
Mine came with bulbs, which I've never changed out, so I can't answer that question.
Sometimes my left headlight takes a while to 'warm up' for some reason, and my electrical is good - the headlamps are on a separate relay - so I think it is an issue with the bulb.
