LED Lights
HJ47th,
Can you post up pics if/when you install 'em?
i have an old school trucklight led headlight and like the bright cool light. only thing disappointing is that they are d.o.t. lights, so they're not blinding bright :D
not that i would run anything illegal on the road :rolleyes:
i do love the fact that if there are issues, the warranty process is simple, and i can beat it with a hammer and the hammer will bounce back and probably knock me out cold before it damages the "lens" cover.
Great article! J.W. Speaker it is!
That is not the conclusion I came to at all. Halogen for the price performance win. The LEDs were not 4x as bright, by any means and the halogens had stock bulbs for the test. Upgrade them to 55w/100w bulbs.
I don't think anyone changes out Halogens for the money savings...
The flicker issue I believe has to do with the CANBUS system used in newer vehicles, I just had to buy an error code canceller which has resistors to trick the computer into thinking it has 55W bulbs on my Ram, it also has capacitors to eliminate flicker. With a straight 12V you should be fine.
Are you replying to your own post rookie? :rolleyes:
