I found a bulliten from toyota that explains how to disable the drl at the drl relay by removing the wire (pin 2 ) from the connector D8. the only downside is the auto headlights will not work correctly after this mod. I really like using the auto headlights. Anybody have any inputs or ideas?
When you installed the new LED's did you replace that plastic cap that was on the original bulb. I thought I read somewhere not to do that as the LED's run too hot to use it. ThanksHere we go, easy install and they look awesome...very bright! I also changed the running lights (168s) with some LEDs I had left over from Pfrans interior kit. Can't wait to check them out at night.
after thinking that my daytime running lights we're not working someone told me that my lights were flashing so if for some reason they flash sometimes but are not on at all most of the time. I guess I'll find a way to disable the drl. If anyone knows a way to disable the drl let me know please
I replaced the halogen DRLs on my BMW with LEDs and had to install load resistors to eliminate the flicker and to prevent a warning light on the dash. Don't know if this would solve your problem but might be worth a try for $7 plus shipping. Try calling DDM for advice. I'm thinking of doing this mod on my LX470 DRLs and will report back with the results.
I tried an H1 LED bulb in the low beam projectors on our LX470, unfortunately the bulbs wouldn't fit in to the hole on the headlight housing. Even if they did, the back of the LED bulb would have prevented the dust cover from going on. Below is a link to the bulbs I tried:
http://www.amazon.com/Automotive-LED-Headlight-Conversion-Kit/dp/B00TF3IXAW/?tag=ihco-20
I really like the LEDs in our LC, but I'm not sure any of the H1 LED bulbs will work in the LX housing?
I will probably go with some HIDs in the stock LX projector housing, if anyone else has had any luck replacing an H1 bulb on the LX projector, let me know.
Thanks
Lee
the cheap $25 kit off ebay worked for me H1 in the LX used the same kit in my daughters z3 think i ordered the 600 series for color... was a simple install....
'04 LX470
'00 LC
