Cruiserdrew
On the way there
Those paper gaskets are brittle and tend to crack as you slide the 3rd member into place. If you get it in with fully intact gasket they work great for decades. But, even being careful, I'll bet I crack 1 out of 3. I really hate that instant $8 waste. When I recently put my 80's new diffs in place, I used Toyota FIPG after I cracked the only rear gasket I had. It's good so far.
You gotta pay your dues cleaning the surfaces though. Clean, bright, shiney, checked 3 times!
One other tip-the 80 front diff tends to squirm around under torque and mess up the gasket. You have to check the torque on the nuts very frequently and keep them tightened to spec. Those little mini-truck studs in my view just are not up to the task, and I wish toyota had used their usual 10mm studs instead of the 8mm studs. I may drill and tap for the bigger studs next time it's apart.
