... By the way I sometimes go over the Boulder barriers out at the entrance of logging roads to prevent people from wheeling, so I've smacked a few rocks.
So, the land manager closes a route and you go anyway? This is the type of action that destroys the reputation of responsible OHV users. For those of us who fight for OHV access, this is one of the biggest obstacles, have examples of this type actions thrown at us all of the time. Speaks, enforces their fear, conviction that the OHV community can't be trusted to do the right thing.
... Schedule 80 is some tough stuff for sure, but it is more brittle by itself is the only issue. Then you go and add heat to points along the length creating weaker more brittle points. But as long as the LCA tubing is nice and tight inside the Sch80, you should t really have issues.
Poop pipe is low carbon mild steel, designed to be bent, welded and often used in applications where failure/leakage would not end well, gas, steam, etc. In other words, ductile, for this application, not significantly more brittle than any other tube. To meet the spec it is tested, bent, flattened, etc, could be argued that it is tested more than tube. It's cheaper mainly because it's common, lots of it is made, and the dimensions are not as tight, not an issue in this application.
... Personally I look at it like, if I'm driving down the freeway and my daughter is in the back and some previous damage to the LCA results in a catastrophic failure going 70mph, is my cruiser going to remain controllable until it's safely off the road? Or is it going to dip to one side, steer my cruiser from the rear a bit and cause a rollover which could result in my little girl getting hurt? Regardless of the the way it would play out and the mechanics of losing an LCA on the freeway, I would never take that chance and my material for the top and bottom control arms was heavy wall stuff and ran me $78 for all of it. $78 of assurance my little girl is protected. Either way you go, it's all in how you use your rig and what you feel comfortable with. I always say, if there is a question of safety cost shouldn't be a consideration, you can always save and wait.
The predictable "my kid is important" FUD argument gets drug out! So the rest of us are disposable?
For that, one would think that you would only run arms made by a reputable company that only employs certified welders?
Have only seen one rear arm broken and it was in a significant accident and the bolt hole was compromised at the frame bracket. It could be easily argued that any reinforcement method used by a competent fabricator will be significantly stronger than stock. On the ones that I have seen fail, (one adjustable came loose, unthreaded/stripped and several bolts falling out installed by the "don't believe in torque wrenches" crew) didn't hugely affect handling, some were only found by looking for a clunk, had been that way for a while.
