Late model gas tank straps
Illinois
I have a 1980 FJ40 and am in need of replacing the gas tank straps on my tank. From my search I believe they are no longer available. I am looking to make my own, and was hoping someone would be able to post some pictures and dimensions of the stock straps.
Thank you for your help!
Did you try posting a want ad? Used ones are around...unless you prefer reinventing the wheel.
If you want to leave a VM for me, I have a super-clean pair just hanging around I can sell you. No PMs please.
Mark
I can get that for you tomorrow. Do you have the mounting brackets and pins? The brackets will give you the width.
Thanks for your help. Yes I have the mounting brackets and pins, but the straps were rusting so bad when I got it the tank was just hanging. I don't mind making new straps but would like to have some idea on what stock lengths were.
Thanks again!
Center of pin to where it makes a 90 degree bend on the other end. I get 39" for the thick side of the tank & 33" for the thin side of tank. That will be close but not perfect, it's hard to measure under there. Here's a few pics. The 90 degree end is built strong & breaced to keep shape.
