Largest Winch for OEM Bumper?
I have seen a couple of mudders that have done this with good results ( of course the stock bumper is the mearly the facade covering the fabbed winch basket and fairlead sleeping behind)
There is more than enough space to put a good sized low profile warn in there. How big? I don't know.
Just measure the area available under there. Consider what parameters will be involved in fabricating a mounting plate and fairlead...and then visit the various winch mfg. sites for dimensions and specs.
Then you'll pretty much know what your options are. Example: http://www.gowarn.com/m6000-winch.asp
I had an 8000lb Milemarker behind mine, and don't think anything bigger would fit!
If you are asking me, I used a universal winch plate from milemarker.
What's the largest winch that will fit behind the stock 80 front bumper?
I don't mind cutting a slot for the fairlead, but I'd like a hidden roller if possible....
Rick
You're going to need this then. :)
OK, sorry to bring this one back from the dead, but I'm still undecided :doh:
I was all set on getting a WARN M8K since it's a sure fit and can be easily had on the cheap :cool:
I was gunna place an order this week, so I scoped out the specials at WinchDepot and saw that they have a Mile Marker 12K for just $46 bucks more than the WARN M8K :eek:
According to the specs, the MM is just slightly larger than the M8K, but with a far superior pull rating :cool:
WARN M8K:
21.04" L. x 6.3" D. x 7.6" H.
Pull Rating by Layer:
1/8,000
2/7,280
3/6,670
4/6,230
Mile Marker 12K:
22.1" x 6.5" x 7.3"
Pull rating by Layer:
1/12,000
2/10,200
3/8,400
4/7,300
5/6500
Now from what I've read, it seems most folks will take a WARN over an MM any day of the week when comparing winches with similar pull ratings, but is there any reason why I shouldn't spend the extra change on the MM in this case?
I personally feel the M8K will do just fine for my minor winching needs, but we all know bigger is better ;)
My OEM winch is on the way. Wanna buy my Warn HS 9500? :D
Others might definitely be interested if the price is right. PM me if you are serious.
I'll surely keep that in mind when the OEM one arrives. :)
Didn't you have a Warn 12 or 15k up for sale not too long ago :confused:
How many winches are you gunna go through lol??
BTW, PM me with details on the current winch ;)
Good memory! Yep, that was me. :)
I have to admit that I should have never sold that 12K, although it was a lot heavier than this HS9500. I thought that I didn't use it that much to permanently carry that much load in front of my truck. Be aware that the 9500 needs spacers to be able to fit in an ARB bumper.
I've gone through 2 different winch setups in the past 8 months and 3 sets of wheels/tires in the past 15. :doh:
