Knuckle rebuild help
Juneau, AK
I've been working on getting my knuckles rebuilt, and I've already managed to put it together badly once...
Now I'm trying to take it apart to adjust the preload (original shims aren't enough) and can't get the passenger's axle shaft out. When I put it together last night it wouldn't turn, which is what raised a flag in my head.
I pulled the spindle off and it was sudddenly able to turn again. It turns out that the birf is what was keeping it from turning. Does that mean it's not in far enough? The birf came out easy enough but now the inner shaft isn't coming out.
I did a Marlin Tack on it while everything apart and installed an ez locker in the diff. Could it be that the tack is too far outward on the splines and is now jammed into the side gear of the locker? I made sure not to let any of the tack get farther out than 1.5", and ground it pretty close to flush.
Help!
Sucks, sounds like you've got it figured out though. By what you've said it makes sense to me. Not sure what a Marlin tack is, you mean a weld? I wanna see what it is when you get it figured out, so post pics if possible.
So how you gonna get the shaft out now? Nothing like answering a question with a question ;) .
You got the Birf bell off already? If you got a welder might think about welding a nut or loop of somekind to the end of the shaft then put a slide hammer on that, being careful with heat. Just worried about messing up the splines on the snap ring area. Whateva you do let us know how it works.
you shouldnt need to have the birf and spindle on the knuckle when youre figuring out the shims.
If the shaft is still in there, I would give the diff a spin and see if somehow that frees up any binding on the axle shaft. If not, seems a welder is your friend. If you have a stick welder, maybe you can get the rod to stick to the end of the shaft and pull the shaft with the rod. If you weld up the splines by mistake, just file down the welds so the splines are correct again.
good luck-
Dustin
I just did the knuckle rebuild and I marlin tacked mine too. I put a link at the bottom if you’re unfamiliar with the technique… I didn’t have any issues with getting my axles out. I did however have a problem getting one side in. Ended up just spinning the third and everything went in fine.
If your preload is too much, you’re going to need to add more shims. I did a thick and a thin on top—both sides. Driver side needed a think and thin on bottom, passenger side needed two thicks and two thins to get the preload correct. I think I have extra shims (whether you have the small or big pattern for the early/late arms) or you can order from SOR. If you need more to get it correct, let me know and I can drop them in the mail.
:grinpimp: Mike
http://www.off-road.com/tlc/cheaptricks/clipweld/
My mistake, the preload's not too much, it's too little. I was tired, wasn't thinking straight (then went home and washed my wallet in the laundry). It's a good thing I quit when I did last night!
I know that the birfield doesn't affect the preload, I just don't think it went in far enough to allow it to turn. I'll try spinning the pinion.
I followed the directions on off-road.com when I did the tack, and I was paranoid about getting it wrong. I really hope I didn't.
Well, got the shaft out. Had to weld a nut on the end of it, chain the housing to a forklift, and come-along the darn thing out. Looks like the Marlin Tack is what did it. I followed the directions exactly too :(
I'm going to try running the front without the snap ring or a Marlin Tack. I think that it should be fine with the EZ-Locker in there. Just need to get a replacement shaft now.
here is my thought on this whole marlin tack. It's hard to know where to put it exactly and if you do it to far out you are screwed like the person above. Could you not put an o ring around the end of the axle without the axle seal in place then assemble it. Then take it back apart the oring would have been pushed up and tell you exactly where to tack.
What do you think?
It sounds to me like that's a good idea, but I would do it before taking the old snap ring out of the birfield. You'd also want to be very sure it didn't rub on the housing on the way out, since that might make it slide back down the shaft. Gear set-up paint might work better.
But since I'm running a locker now...Meh.
