Key Problems
Nashville, TN
Ok guys. Stick with me on this one. It’s an f’ing head-scratcher.
Got my new-to-me 97 cruiser a few months back and it came with a single key. That key worked fine for locking/unlocking the driver’s-side door and for starting the truck. I never got it to work in passenger-side lock.
After a month or two the key (well worn with age) began to have trouble turning the ignition. It would do it but it required a lot of fiddling.
So I ran up to my local dealer and had two new keys cut based on the vin. The new keys work great in the igniton but won’t work in either of the front doors. They work fine in the rear hatch lock.
I would have assumed that maybe the door locks were changed out at some point and are different from the ignition but the fact remains that the original key unlocked the DS door and worked in the ignition. The new keys and the old one look very similar but the old one has considerable wear and is smoothed down in many areas.
Based on some searching here I have repeatedly tried squirting WD-40 into both front locks and tried to get the new keys to work but they won’t budge.
Any ideas what the heck is going on? It sucks having to use one key to get in and another to start the truck - plus the risk that the original key gets lost or broken or just stops working in the lock and I have to start crawling through the rear hatch.
Thanks!
When I had keys cut at the dealer it took two or three tries. I think that out of the first 3 I had cut 1 worked in all doors and then I kept having new ones cut until I had all of the keys that I wanted. In short, they may have not done the best job getting the cuts right. It's also possible that wear and/or gunk in the lock cores is causing issues, etc. A locksmith should be able to help you if you want to stay with the stock/vin keys and need work done on the door locks/etc.
I disassembled, cleaned and replaced pins on door cylinders on an FJ80 years ago . I replaced worn pins with new ones and lightly lubed the cylinders. It's a diy project if you have patience and are organized. I did not disassemble the ignition lock. I used a new steel key (not alloy which is softer and wears poorly).
The only problem I can think of with a steel key is that the pins in the lock are usually brass. Wouldn't the steel key cause the pins to wear more? I would think it would be easier to replace a key than pins.
I would try having a key cut from the original and just break the sharp edges with 100 grit sandpaper.
same issue. the original key opens Driver's side door and ignition but not passenger side door. minor annoyance. hope it doens't starts giving me trouble with the ignition.
These keys are definitely not easy to cut, I tried yesterday and it took them about a half hour and a few tries to get them right.
It turned out my old keys I'd been using were the valet keys? and the new keys worked in all the locks where the older key would not. The new keys have a large shoulder at the base where the valet key had a taper.
The FJ80 in question is a '92. I'm good with replacing pins every 20 years!
A locksmith told me he just loves it when his customers use liquid lubes like WD 40 on their locks. He said liquid oils attract dirt, binding up the pins inside the lock. Thereby making him money in service calls when he has to go open their lock. He said the best lube to use is dry powdered graphite, it doesn't attract dirt and grit.
Yup. To add to that, WD40 is NOT A LUBRICANT. It is a solvent. it's for cleaning things, breaking up rust, crud, etc. Not for lubricating things.I cringe whenever I see someone trying to lubricate a door hinge with WD40.
Dry graphite for locks. I just had my rear lock cyl out and the thing had been packed full of grease and crud... make sure to clean that all out before you add the graphite.
WD 40, as I understand it WD is for "water displacement" and "40" is the 40th attempt at the formula. I keep it around but it's rare that I find a use for it. Came in handy for coating the exposed block on my 80 while the head was off though. It also gums up when hot as I recall so for many reasons it's not the go to for very many applications.
WD-40 - Wikipedia
I spoke to a locksmith once and he mentioned that different graphites are required for different climates.
Forget the specifics though. Proceed with caution....
WD-40 is garbage, and there are several other lubricants ( and WD is not one ) Google is great for questions like this . It drives me nuts in this day and age people still use that crap there are real lubricant available :deadhorse:
Really? I had the flunky cut me a couple at the local drug store. Works just fine. They had what looked to be an idiot-proof cutter. At least it was that idiot proof.
I think if they are cutting a copy it’s different than if they are kutting new, from a code (to be fair, it may have been a system thing...or that the guy was new, idk)
