2000 LC 2uz-fe V8. Buddy brought it to me with clickity clak serpentine belt noise. I think okay, idler or tensioner. As Im backing it into the shop it throws the belt. Upon inspection belt has removed itself from the passenger side. I notice that the PS pump pulley is packed with belt material (first pic) The truck appears to have a relatively recent idler pulley replacement. So maybe they had a seized pulley.
When it threw the belt it dont not actually break the belt in half. Just the forward most rib broke and for some unknown reason it decided to jump off the pulleys.
Here is a weird part all the pulleys except the alternator feel smooth and free. Alternator spins but its very sluggish with a slight bearing noise. Replace Alternator and belt. Clean rubber debris off of pulley. Re-assemble clicking is gone. I let it idle 20-30min. All good? No.
Buddy reports he is driving the truck, traction control light (and/or other lights) blinks and he pulls over and hears claking. He calls me and I respond to find the belt is still holding but the forward most rib is busted and a loose partially attached piece of belt is whipping around causeing the clicking noise.
Now I am perplexed. As a domestic car experienced wrench. I cant think of any car I have seen just throw belts without obvious bearing damage since the age of V-belts.
New belt and alternator has the correct number of grooves. Every pulley spins smooth and free. Customer reported that he drove with AC on for appropriately 45min-1 hour before problem .
I am thinking tensioner spring weak or maybe AC compressor clutch being worn enough to allow it to contact belt (?)... Is that even a thing? The metal hub on the AC clutch appears to be oversized enough that it could theoretically contact the forward most edge of the belt if say the clutch material had worn down enough. But I am not sure if that is even possible. Never seen a problem like that before.
I am going to dig into this further, but I know these motors are notorious for belt problems, so I am just fishing for leads.
