I feel like I have seen this setup before on MUD. Maybe something similar.
Um yeah, so his dealer quote was $9k to fix the KDSS.
What does that say about LX drivers?…The devil has a lot of advocates…Depending on how you look at this, this may be an opportunity, or it may be a problem.
Playing devils advocate on the opportunity side. Especially if the rest of the mods are to your liking. KDSS delete has been going on a long time in other toyota rigs like the T4R and GX. Maybe look into some of those forums.
The harder-core modders consciously delete the system. Sure there's cons, but there's benefits too including better independent articulation for smaller lower amplitude bumps that KDSS won't necessarily disengage for. Fire roads and washes are an area where KDSS has the potential to limit capability. Modders have found additional stability and speed under these use cases, with less tossing side to side.
Some ways to compensate for less or no sway bars is to increase suspension spring rate. Many are already doing that and begs the question if there's too much roll resistance when KDSS is paired with stiff springs, particularly in the use cases where KDSS may not disengage.
Those that do KDSS delete seem to generally only replace the front KDSS bar with a static front bar. There's ways to get a rear bar in too without much fabrication and cost depending on your resources.
Personally, if I were in that situation, depending on the deal you got, it may be a good opportunity to go further down the modding rabbit hole. There's just as many that probably shouldn't.
Wow. That is some seriously good detective work.
I'm curious where your data comes from about what is needed to "disengage" the sway bars?
My understanding is there is no threshold.. as long as one side of the vehicle compresses at the same time the bars limit disagreement between right and left sides (reduce roll). If anything happens that the compressed and drooped corners are diagonal, they don't limit anything.
"No" threshold is a blanket statement. To some extent there will be friction in the passenger side suspension twisting the sway bars in their mounts, that won't exist on the driver's side. But there are no valves within the KDSS system that only operate to link one cylinder to the other above a certain pressure delta or anything of that sort, which is what would be needed to set a sway bar disengagement threshold in a hydraulic system.
The current KDSS mechanical system unlocks in a the classic articulated situation. Namely when front to rear axle moves out of phase, it unlocks. In phase like a cornering situation, it'll remain locked. One takeaway from this means that each axle cannot response singularly, and depends on it's action relative to the other axle. Independent in some ways, but locked in other ways.
A great way to understand where the limitation is, is to look at the new E-KDSS system. With electronic controls, it can respond to a broader set of scenarios. To engage or disengage sways of the front and rear axle independently.
forum.ih8mud.com
