No answer to my question on the 60 series side - anybody here that can help ?
( heading should read KC859-250s )
This is for my 2F rebuild currently being done
I could not find a suitable secondhand camshaft to act as a donor , so I bought a Melling MC803 camshaft to send to Delta .
( my original lifters I kept and had been refaced locally )
I communicated with Delta camshafts and told them my requirements for the engine I am rebuilding . To my surprise they advised the KC859-250s grind and not the KC859 ( 262*duration) grind .
I just want some feedback from anyone else out there who runs this cam . ( very little info from a search as all seem to run the 262 )
Specs on the two grinds for those who do not know :
Perf 262 grind
Duration intake 262
Duration exhaust 267
Duration @ 0.050 is 217
Intakes opens 24, closes 59
Exhaust opens 62closes 34
58* overlap
cam rise .284 L/C 108 degrees ( gives 0.430" valve lift )
Lash intake .014 exhaust .014
Perf 250 S grind
Duration intake 250
Duration exhaust 254
Duration @ 0.050" is 215
Intakes opens 17, closes 58
Exhaust opens 60 closes 14
31* overlap
cam rise .255 L/C 108 degrees ( eq valve lift of 0.383)
In another thread Mark W wrote : Quote:
A camshaft with a duration at .050 of about 210 to 217 and a lift in the area of .240-245 will produce a notable improvement in mid range and high rpm power. At the sacrifice of a small amount of peak bottom end power (below 1000 rpm).
So both fall in that category
Other comment ?
Perf 262 grind
Duration intake 262
58* overlap
Perf 250 S grind
Duration intake 250
31* overlap
Other comment ?
