Was that head checked for cracks? Pressure test, Magnaflux or both?like doing a HG job when not needed!
Have you pulled spark plugs and inspected for signs of water still getting into your cylinders?
I'm not opposed to throwing the kitchen sink at a problem and ending up with an LS engine in my Toyota but it would be nice to see this through if for nothing else closure.Not pulled plugs yet, I should have time to work on it some more later this week.
In my limited experience, the first thing any decent machine shop does is check for cracks. They don't want to waste their time either...Was that head checked for cracks?
Snow version? Is there a not-plastic snow version?
Installed new rad cap and topped off water at the head and rad
Sprayed carb cleaner all around, no audible change in idle speed
Let it idle for 10 minutes with some spirited throttle pulls
Top and bottom rad hose are the same temp. Both are too hot to hold and both are pressurized the same by feel. Head heat seems reasonable.
Top of rad is 180ish, it was hard to get a good reading at the bottom of the rad, but it read 100* lower? But again, upper and lower rad hose read the same temp.
After I shut it down, back of head was 180*, the front of the head was 205*
Not driven it yet.
If the radiator were dumping heat to ambient air, the outlet (lower hose) would be cooler.I'm leaning rad now too. it only misbehaves at speed.
its also 50 years old I guess, it looks OG
HOWEVER, the upper and lower rad hoses are the same temp, no matter when I check them
rad and water pump are on the to-do list, cause why not!
