I think that 20 secs is not that long for a carbed motor.
crank it till your battery dies or starter smokes.....then you have done something.
Tank is new and metal and fuel is flowing freely to the pump, it's from pump to carb it has now vacuum.....I think bc I haven't generated enough cranking for suction to start.New tank =greater concern from me. Metal or plastic?
This can be a bit dangerous but I would get some sort of squirt bottle a get the truck running with that. Keep it running with the squirt bottle for several minutes. If the fuel pump does not pick up then you know you still have a problem. Don't do this if you are getting any backfire through the carb.
Honestly, I have never had to change the fuel pump on a Yota 6 but on other makes it is possible to install the dump with the lever under the cam lobe and get no pumping action. Hope that's not the case here.
Make sure there are no kinks in any hoses. I ran a straight inlet/outlet filter for over a year not realizing that the straight inlet was kinking the hose. I switched to a 90* inlet and straight outlet and solved the poor idle/low end situation.
QUOTE]
could I get her going with gas to the carb directly and feed it to keep it going for say 3 minutes and see if that worked or should I actually run a line from a gas can to the carb and dump fuel in that way?
trying to avoid blowing up my truck or burning/toasting the front yard and garage!!!! if this isn't fixed manana....im calling an all hands available wrenching/scratching session Friday morning.
Didn't read the thread but I'd be surprised if the cam lobe is worn out. You can use a vacuum guage to see if it's pushing any vacuum on the output side of the fuel pump. I have one you can borrow, or you can get a cheap one at autozone that would do the trick just fine.
I hope your right...ill look into a gauge tomorrow if I can't get it running after a few more tries.
got your pm ill call you
I've not seen the pump , but if it's a lever-driven one like the other Japanese cars I've had, the lever would ride on an eccentric on the cam and any GEAR on the cam would be used to drive something other than the pump (distributor, etc.). Having not seen the pump, I certainly could be wrong, but that's the way the ones I've replaced worked. That being said, with no more pressure on the cam than a pump puts on it, it's hard to imagine wearing through the case hardening and wearing the fuel pump lobe off of it.......if the PO's ever changed the oil in it, that's not likely to have happened.Thinking while I type, but IIRC you could pull the pump and stick a screwdriver down in there to feel the gear on the cam that drives the pump to make sure it's now gone. I think I remember feeling the gear engage last time I did one but it may have been a decade now...
Didn't it run OK with the electric fuel pump?
The pumping action of the fuel pump has nothing to do with any external intake or exhaust gaskets. The pump itself acts independently of those. Next, the action of the accelerator pump in the carb will take you from idle to off-idle (higher) RPMs where the vacuum of the engine works through the venturi effect to pull fuel / air into the engine.Ok I cranked and cranked and my battery is almost dead....I did notice one thing.....when I got her turned over I saw an ever so slight amount of light white smoke coming from the gaskets im pointing to...the lower one is to the exhaust so that makes sense...the upper though...do I have a VACUUM leak and THAT is why it isn't getting suction for the fuel pump???
I have a new carb in a box and could just replace it with new gaskets etc. if yall thought this was it....the PO said last night that everything worked he just wanted to push fuel not pull it EXCEPT for the random chugging for gas and shutting off for 15 minutes....I wonder if that gasket was getting hot and expanding so that there wasn't enough vacuum????
thoughts, ideas, stupid comments, jokes?
Euclid if you want to come over this afternoon and see what im talking about I would love another opinion....or anyone else interested.....PM me for directions......im close to the spillway-old fanin area. It will take 10 minutes and we can drink a beer and ponder the cosmos.....
Based on what all you have said, you've cranked it enough to where there there should be fuel already entering the carburetor PROVIDED (a) your mechanical fuel pump isn't somehow installed incorrectly (not likely, unless you figured a way to get the lever situated on the eccentric where it's working against itself, rather than pumping) (b) your new mechanical fuel pump isn't defective out of the box or (c) your accelerator pump isn't bad. Now, you could have any of a MULTITUDE of things wrong with the carb itself (and if you have a new one, why don't you just go ahead and install it and take that variable out of the equation?), but as far as fuel delivery goes, you've got an exceptionally short route that's quite uncomplicated, and if the mechanical pump is installed correctly / functioning properly, you should have fuel to the carb by now........heck, if you got it started by pouring fuel in the carb, that should have provided enough pumping action to make up for a lot of starter cranking.......keep us informed
She is running like a top.....the 76 model just needs 1 gasket no spacer like I had installed. The fuel arm was probably a 1/4 inch from the eccentric. Thanks to all for the advice and to Euclid and Andy for coming over to help me trouble shoot it.....id go for a drive but im in the closet with our livestock, a crying baby, the wife, and mother in law listening to straight line winds.....Happy freakin new year!
Njoyed hanging this afternoon. You and andy both did good and have a great start for the land cruiser sickness.
