Mine looks just like that. I just used a shorter piece of hose.
but it was actually a good thing since it needed to be changed.
I ordered the fuel pump gasket a couple months ago at Herrin Gear Toyota on 55 North Frontage. Picked it up 3 days later.
Mine quit in the middle of "The Canyon" trail at GreyRock. I had my Toyota spare and gasket because the one that failed was obviously aftermarket and I didn't trust it. Jeff Davis and I swapped it after pulling the battery out. It was very hard to get to. Be sure you get all the old gasket/sealer/etc off the mounting surface.
That's funny. Same engine in a different truck (60) and the task is stupid simple.
you wouldn't believe how tight it is around the fuel pump because of the radiator, and lack of space between the block and inside fender.....I might actually have to buy a shorter screw driver to get in there......and all that with the ample space in a 40 engine bay is ridiculous.
I have some tools that may work in the tight space. I can bring them by thursday morning. You could also remove the fender to make everything easier.
well done!
