You move the metal (not plastic) perforated tube over from the stock filter housing. As said previously in this thread, you don’t use additional (factory) sealing washers with the fumoto valves. You use the large o-ring that comes with the factory filter kit (there is no longer a place for the smaller o-ring on the Bjowett filter).Received my Jowett Housing with all the fixings. Looking forward to the next change. I have one clarification question. I have the ez drain valve for both the Jowett Filter housing and the Oil Pan. Do I use a new washer that you normally would with the normal drain bolt for the oil pan when installing the ez valve to the oil pan? I ordered a few of these when I ordered my TRD filters just in case (cheap). Also, just to confirm you only use the large rubber o ring shown in this thread on the Jowett housing? Don’t use any other o ring that comes with the TRD filter? I understand how to remove the old plastic filter tube and install in the Jowett filter housing and the main large o ring on the Jowett housing. Thanks for the help.
