The distributor is a small cap electronic distributor off a 1980 I think.
I might have a spare dizzy with a low-miles cap. I'm probably never going to use it...I started making a list, cap n rotor, capacitor, coil with internal resistor and I found the cap is unobtainium. Now what?
I went through a similar troubleshooting process on my 79 and found my oem electronic distributor had too much axial slop and my igniter was out of spec per the FSM.I’m pretty sure it’s my coil. I’ve decided to take it back to stock by replacing the distributor with an OE unit. I may need to replace the igniter too because the one I have is from a 1980 with electronic ignition. Does anyone know if I can modify this igniter to work with a points and condenser Distributor?
Just curious, since you have a combination of different years (later distributor/igniter vs earlier harness), have you verified that you have a ballast resistor or resistor wire between your ignition switch and coil?Thanks everyone for the many good suggestions. I’ll definitely check out Coolermans web site again and see if I can find something I may have missed.
Here’s the latest: I bought a new coil and it didn’t change a thing. Runs perfectly on start up but deteriorates quickly once it reaches optimal temperature. It’s possible the pickup in the distributor is failing so I plan to install the points distributor I bought from City Racer next. I’ll need to get a ballast resistor before I do that though. This sure has been a frustrating issue and I sincerely appreciate the many helpful suggestions
About how long, in minutes, does it take to start deteriorating if just sitting at an idle?Runs perfectly on start up but deteriorates quickly once it reaches optimal temperature.
