I have a 77 FJ40 with a desmogged 2F and what I believe to be the original Aisin Carb. The truck starts easily and warms up quickly. Within just a couple of minutes it’s happily idling with the choke completely off. I can drive it to town ( 10 miles ) shut it down and then 5 or 10 minutes later start it back up and head home. On the return trip it’s harder to start and idles poorly. It stumbles on acceleration and generally limps home. While it’s hot and unhappy I’ve been unable to adjust the carburetor and improve the situation. It feels like it’s just not getting enough fuel but I could be wrong about that.
So far I have pulled the manifolds off and had them machined. They put a new heat riser block off plate in and I installed the manifolds using a Remflex gasket. I also pulled the carburetor and rebuilt it myself twice. The engine pulls 17inHg at idle ( 1000 ft elevation) with the timing set at 7degrees advance. I’ve sprayed WD40 along the intake and carburetor base without any change. I’ve plugged the brake booster hose too but so far I haven’t discovered what the issue is.
Any suggestions about where else to look?
