Part 6
Next take the wire/plug that you pulled out of the ceiling and take your safety pin and push/pry downwards on the little plastic clip that is holding the wire in, and lightly pull on the wire to remove it, you might have to take the small flat-head screwdriver and push a little bit on the terminal inside the plug to get it out once you have cleared the plastic tab inside the plug(see pictures 1 and 2) you will have to do each one, but I recommend doing them separately just to make sure nothing touches together and shorts out. Next step is to strip the wires on the LED lights, not the main wires/plug that are physically attached to the LED strips, there is a plug that comes with the LED strips that plugs into the main plug on the LED strips, take the two wires that come out of this plug and then strip off about three quarters of an inch of the wire's sheathing (see picture 3) this is going to be a good point to test the polarity on the lights, all of the wires, on the truck and on the light strips are color coded, so figure out which ones work exactly for your model year and then feed the respective wire through the plug (see picture 4) (side note the solid black wire on the LED strips, and the red wire on the truck was the correct polarity for my model year, but just double-check to make sure) and then take the stripped wire and feed it through the hole in the terminal and wrap it around the terminal (see picture 5)
#1
#2
#3
#4
#5
