Good update. Thanks!
Getting to the rear, the exhaust bends up and crosses over the frame rail into a stainless Vibrant Performance muffler which does a fantastic job of making it sound sporty yet quiet for when you are properly overlanding. A few posts ago, I talked about how how the 4.88 gears and the turbo performed. The thing is an absolute ripper!! It is so much fun in the sand and the mud! It builds boost and you get fantastic wheel speed and you hammer through anything! It is a riot! However, its a two edge sword, because I find myself having to sit at 2800-3k rpm when trying to cruise at 75mph with highway traffic. So here is the million dollar question. Is there a way that I can keep high range low speed and low range wheel spinning fun all while being able to lower the rpm while on the highway? I have been looking at transfer case gearing but I am a little turned around with the lingo. Underdrive v overdrive and so on. Any help would be amazing! I have a video of what sorta fun I have tried to describe, if anyone is keen to see it!
There is a set of gears that can give you a lower gears in low range and a higher cruising gear. Get ahold of Kurt from @cruiseroutfit. I would give you something like 33% lower gears in low range and 10% higher gears in high range so your 2800-3000 cruise would be 2520-2700.
What size are those tires? Look too small for 4:88 if you want road use as well. Stock gearing with underdrive low range would suit you well I bet.
if you over drive the high range only in the t-case you will lower you on road rpms and keep the same low range for crawling and such. it should equate out to about 4.56 in the axles give or take a little bit either way. if you under drive the high range that will increase you r road rpms but will be better at low speed for off road.
if your satisfied with the low range performance than i wouldnt even bother with the low range gears
Simply put, the engine is burning a lot more gas to make a lot more heat to make the power your foot is demanding. Do you get hotter when you exert yourself physically even though your cooling system is working?There is beating a dead horse and then there is taking about cooling/radiators etc with the 1fz engine. My question to you (short and sweet) ((I am not looking for what brand to buy or any of that either)) is, can you tell me what is to "blame" for rising coolant Temps when under load that then fall when idling? Always looking to make improvements. Thanks in advance! P.S. I had this question prior to the turbo as well.
Higher rpm will reduce load by reducing manifold pressure. If I were you, I’d stick with the gearing set up you have and maybe just toss a set of the 3.12 low range gears in the transfer case. The 1fz revs freely and cruising at 2800-3000rpm makes no difference to you engine. In fact max torque comes in at 3200 rpm so theoretically, this is an efficient rpm.
Thank you! Time to do some more researching/budgeting.All of the parts you mentioned that could possibly improve heat shedding are available. Joey @NLXTACY at Wits-End would be the man to talk to about this.
The low range transfer case gears play no part in high range street driving but would give you about 25% lower crawl ratio. On the other hand, the under drive and over drive high range gears do. Under drive will boost rpms about 10%, something you don’t need with 4.88’s and 35’s. The overdrive gear set will mimic at set of 4.56 axle gears, or there about, and your rpm’s would be decreased about 10%.
. Today, I'll reconnect the downpipe and open up the exhaust right before the muffler to rule out the magnaflo cat is indeed high flow. I have 2.5" all the way to the muffler inlet.
