It's Another Overheating Thread!
Saint Simons Island, GA
Website
southeastadventure.com
I've searched and searched and can't find any similarities to my issue at hand on MUD. Here's what happened...
For the last month and a half, I've been driving with a faulty knock sensor on bank 1 (P0325 code). I finally got around to replacing it and the CEL is cleared and hasn't come back on in the last week. And she's running much nicer. However, yesterday as I was driving home from work I noticed my coolant temp rising & rising. I found a spot to pull over and kept RPMs up to cool it down as it kissed 230*. I had some coolant come out of the overflow and my heat died. Intake temps were about 66* and the only grade was a bridge over the Inter-coastal Waterway. I limped it the rest of the way home floating between 210-220 and kept it revved in the driveway and misted cool water on the front of radiator to cool before shutting it down. This all happened within a 20 minute drive. Fortunately, no steam or sweet smell from the exhaust.
With the bad knock sensor, temps were staying under 200.4* consistently.
Since owning it, I've replaced the fan clutch (modded blue hub w/ 20k), thermostat & gaskets (OEM), distributor cap, wires and plugs and I've also flushed the coolant. I have a new Koyorad radiator on hand and will be replacing the old one (supposedly replaced recently from PO) and flushing the system again. I also have an AISIN water pump as a just in case measure.
Has anyone else had this happen? Could I have messed something up coolant wise on the driver's side of the block?
Thanks!
Pressure test yet?
Start with the chap and easy. Is your fan belt tight? Are you loosing coolant? What does your coolant look like? What does your oil look like?
Have you ever replace your heater valve?
Pressure test yet?
I had to work all day and haven't been able to pressure test yet. Planning on doing it tomorrow.
Fan belt is nice and tight, only coolant loss was from the overflow and is nice a light Toyota red. No sludge in oil, yet. The PO replaced the heater core, AC and all hoses including PHH and rear heat.
Did a head gasket job (preventative and theraputic maintenance) on my 97 LX450 about 7 years ago. The scan guage indicated a drop in temperature from 186°F to 179°F with normal conditions by just doing that. Give it a shot.
How old is the thermostat? Is it a Toyota thermostat? Same with rad cap?
Since you have the parts ready, flush until clear a few times (including rear hoses), and install the new rad and water pump. Should be good.
New radiator, water pump, and test your thermostat by fsm steps. Hope it’s good.
I agree that since you had already purchased parts go ahead an install but i have a hard time believing that it will correct the problem that just popped up. I think you will still be looking for an issue when you finish but good luck
Having been down this road recently I will offer my thoughts:
1. Be really true and accurate about coolant consumption. When I saw temp swings it was because I would get a bubble trapped from air in the system from a small leak in the head gasket. Patched it with a liquid HG repair for now and seems to be holding, but will still sip coolant if run all day.
2. Water pump is a likely culprit. When I saw the exact spike like what are talking about I repaced the water pump and all has been good since.
I know I have an underlying HG issue that will need to be addressed at some point. I just watch temps and expect some coolant consumption.
So this happened on the grade?
I agree the rad will likely not correct the problem. You can purchase an infrared thermometer and check the temps in and out of your rad before overhaul to make sure it’s flowing and cooling.
After the pressure test, shore up any leaks and have them suck out the air from your system (there’s a machine for that). Drive up a long grade and test.
Unfortunately an overhaul of the cooling system involving removal of the head is recommended to grab the bull by the horns, but maybe there is a leak, that will cause spikes when pressure increases.
Thanks all for the replies. This is just what I need to deal with on my B-day lol. Maybe I'll pull enough b-day money for the HG job but as a kayak guide in the winter, money is very sparse. So it may have to wait.
I'll start by pressure testing the system, scouring for any signs of leakage and hopefully I'll find one easily. Might as well replace radiator and WP since I have the parts on hand and hope for the best until I win the lottery
Winter Kayaking in Georgia. Sounds great! I would imagine business is slow this time of year though. It’s still blooming here in Florida.
As for the cruiser, yes, you have the parts go ahead and replace them. For sure. You have the time :)
I know there are a lot of threads about the cost of ownership, and this is just one more example. While you do save a car payment you have to put some of that money in an envelope for days like these.
I hope it works out quickly for you.
Here are my 0.2
check overflow tank level - often times the system will suck up coolant from overflow if there are air pockets or bubbles in the system to display after shut off. if you tank is empty, it will suck in air and results in spike in temp.
How many miles on it? Original Cats? if over 150k and original Cats....im betting yours are plugged enough that they are causing or at the least contributing to a slightly compromised cooling system.
Thanks, yeah it's chilly here but I prefer paddling in this weather over summer time heat!
Cost of ownership is something I should have considered more before I bought her, but she was calling my name! That's why I've bought parts when I can get a good deal much to the chagrin of the Mrs...
She has 192k on it. I replaced both y-pipe and 2nd cat when I bought it along with both O2's. Planning on pressure testing tomorrow or Thurs, I'll update with what I find.
Well, I didn't get a chance to pressure test the system. I drove it a short while and started overheating again I was able to cool it down before things got out of hand. This time I popped open the oil cap and sure enough, milk... :cry:
Hopefully I can sell my old jeep this weekend to start putting together a rebuild list. Anyone looking for a project 80 with a great interior?!?
