Hi guys. I'm trying to diagnose a problem I'm having with my front brakes on my Aussie spec '84 HJ47.
The pedal seemed a little soft And I also noticed when the road was wet, my back drums were locking up under moderate braking. I jacked up the front end and I am not getting any braking to the front discs. When the brakes are applied, the calipers grab for a second then release and the tire spins freely with the pedal to the floor. Even pumping the brakes there is no change..
- bled entire system with no change. Noticed the fronts, while bleeding didn't exert much hydraulic pressure.
-checked lines for a damage and all look good.
Is it safe to assume my master is bad?
It looks to be a pretty new unit.
Some advice would be appreciated.
Thanks, Justin
Thanks, Justin
