Is this part missing something?
Keyport, NJ
Not sure what to call this part. Something looks like it is missing from it like a bushing or collar or something. This is where the steering collum goes through the firewall. I've been doing some research on some steering problems I have when it's windy and I think this could be the cause. Lots of posts on steering problems but no one has mentioned this part that I have seen. The thing is the truck tracks straight but have to hold slight right pressure. So that's going straight, wheel straight. When I need to correct left I have to go through a dead spot maybe 10 or 15 degrees left of center. Had same issue on my 94'LC. Never really bothered me except when windy, makes for some interesting driving. So I finally look under dash and see where shaft passes through firewall, I can grab this and has enough play to go from side to side in this opening. When driving straight shaft presses against left side of hole, no when correcting left shaft moves to other side of hole and then steering catches. Read about rag joint, thats tight. It just seems to me something should be supporting the steering shaft as is passes through the firewall. Looks like there might have been a rubber boot that tore off but that wouldn't be strong enough I think. Anyone replace this bracket? Part name? What's a new one look like?
Huh? I don't think I have anything there either? I was just messing around in that area running my SIRIUS antenna.
you need a new one.
The rubber bushing is all worn out and your steering wheel is now sloppy.
The rubber dust cover is missing but that part has nothing to do with the tightness of the wheel. All it does is keep dust out. Those dust covers just wear out.
there will be some lateral movement.
Ok, some movement. The thing is my dead spot seems corrolate(sp?) to the movement of this shaft. Because as I move the steering wheel and this shaft moves from side to side thats movment that's not going to the wheels. BTW Dan I'll be calling soon for the knuckle rebuild kit.;)
It does make your steering feel sloppy when it goes it is more than a dust boot.
It is rather stiff and provides support. You probably looked at it because your steering felt sloppy? Thats why i looked at mine.
That boot doesn't provide any support to the steering column. If there is slop it's somewhere else. The movement you get is from the rag joint which is really just a rubber coupling. That could be worn out but that is highly unlikely. Looks at your knuckles and rod ends first for slope. Next would be the steering box.
Definitely a lower shaft bushing has gone awol. If you can't find the part in a FSM then go to the Toyota dealer and have someone in parts show a picture of it on the screen. Shaft should be solid in the steering column housing.
I think the slop is from the shaft because if you look at it as you turn the steering wheel it moves from left to right.......this is before it even starts to rotate......sooooo the steering wheel is moving but the shaft doesn't start to rotate until it hits one side of the opening putting pressure on it. BTW in the middle of replacing belts, not as bad as I thought it qould be.:)
PS Big run on sentence there.
Pull it out and see what your steering feels like. Or take a look at a new part it is a rubber bushing not just a dust seal. It keeps the shaft in the center of that hole. If it gets worn out the shaft will flop around as you turn the wheel. And you will feel it in your steering wheel. Call it what you want it feels like there is something loose.
Exactly when you replace it the shaft will rotate when the wheel turns not after the shaft loads against the hole.
I hope that isnt a wire running through where the steering shaft is............?:confused:
Yup, Uh Oh guess I am going to lose my 1 banana. :confused:
I didn't see anywhere else to penetrate the firewall. It's just my satelite antena wire so nothing major. Better than it running up the door jam like it did for the first 6 months.
bluetribal,
if you open the hood, you can see a rubber plug on the drivers side firewall inside the engine bay- basically just behind the insturment gauges- punch a hole in the rubber grommet and feed your wire thru there.
It's a good access point for any wiring you need to get into the cab.
I'm not touching your banana..........;) you can keep it!!
you will lose your banana if you dont reroute that (trust me you want to) FirstToy is right on about where to run it thru (it wore out the part in question....!)
bluetribal,
Thanks FT, you beat me to it.
Or just ask cruiserdan, he will post the part number. Most of us get our OEM parts at a nice discount from him, he's the parts manager at American Toyota and knows more about LC's than most on this forum combined!
It is simply a dust boot, has nothing to do with holding the shaft in place.:rolleyes:
