Is this part missing something?
My dust boot just broke agian it defineatly does not keep the shaft in place mine goes to the left everytime and breaks the seal. I cant seem to find the fix.
Mine stayed pretty much centered when I replaced it. No way it holds any pressure of the weight of the shaft.
Or just ask cruiserdan, he will post the part number.
The boot (or seal) is a 45292-35050. Current suggested list price $12.98
The lower bushing is a 45273-16010. Current list price is $6.34
The lower bushing requires the disassembly of the steering column to replace. I replaced mine about 6 months ago. So while you are at it get some rebuilt parts for the steering column. At the very least you will need the two break off bolts that hold the ignition to the column.
Other possible things that could be loose in that area are the rag joint and the ujoint just above the rag joint. I replaced those as well, however the olds ones were perfectly fine.
So is the lower bushing at the steering box end or where it passes through the firewall?
It's in the tilt column.
This is fairly simple to trouble shoot. When you turn your steering wheel back and forth where is it loose? It is easy to see if the steering column bushing is bad. The shaft should turn pretty much on center. If it has much movement there the bushing is bad and will wear out the firewall boot very fast. after the u joint the boot keeps the shaft from hitting side to side on the metal. The boot should not have to support more than the resting weight of the shaft if all else is good. It minimizes the wobble in the u joint. Take a close look and see if that bushing is worn out.
You sat on that for a year and a half before you put it in?
:lol:
Yeah, that's why I bought all those other parts for the steering column. I couldn't figure out how to replace it without disassembling the column so that's what I did. So it might have been longer than 6 months ago, but it was after I bought all those other steering column parts.
I'm learning that I'm starting to loose a sense of time the older I get. ;p
Wait til you start decade-shifting.......:eek: :grinpimp:
Dan,
You mean like when I talk about the '84 car I had in high school. Whoops, I meant the '74 car.. Like that? Gads.......
DougM
Dan,
DougM
That would be it.............:hillbilly:
Good thing I read this post before replacing my column dust seal. My steering column does not stay on center when I turn the wheel and it would have definitely ripped the new seal. Is this the bushing that is worn out? If so can it be changed by taking the rag joint apart and pulling the shaft without disassembling the entire upper portion of the tilt mechanism?
Thanks
George
