Is This Normal Guys?
England
Afternoon All
prompted by a rattle/resonance/knocking (diesel type) I ventured underneath earlier and too the following pix and more importantly video (youtube link could not upload here) - its 1982 BJ40 4 speed - slight lift but leafs have been shimmed.
This video taken with all wheels on the ground and gearbox in neutral.
Noise is barely noticeable with windows up but at a certain point in 2nd/3rd/4th with window down it is very noticeable, not just under load - exhaust is new and well mounted.
Thanks soooo much in advance!!
Dan
Way too much back lash in the ring and pinion. Could also be worn spider gears or center pin. If it’s a full float 3rd member needs to come out, if you have a diff cover, pull it off and you will certainly see a problem.
