Is there an original "adding a CDL switch" thread?
Chicago, IL
I have a bunch of questions about adding a CDL switch to my "new" 94 FZJ80 and wanted to get a "foundations of CDL" thread to read and would appreciated a link if you know of one...all the threads that come up in search presume one knows all about it and are all about what kind of switch to use, deleting the pin 7 and so forth...I currently don't have a CDL switch on my truck...can I add one and will it work for me? If so, why didnt Toyota include the switch if all the underlying functionality is there? And, what are best practices for using the switch once installed? thnx in advance!
Go to the FAQ, its discussed in depth. The switch is a a toyota part your dealer can order. It will fit in a blank in your dash space. Toyota didn't add because your center locks upon entering in 4low
hmmm...been there and all I saw in the diff section was the 7 pin mod faq...I must not be looking in the right place...can you specify?
I have a spare switch if you need. Very easy, will give you extra traction in high range. Do not use on pavement as the wheels will bind up while turning. I did not do the pin-7 mod, so it still auto locks in low range.
You should do the full Mod so you don't have the diff locked every time you have it in low
I just did this last week on my 94. Remove the screws on the dash, drop the steering column to the lowest position. Pull the dash out a little for access. Push out the switch blanking plate. Locate the harness - mine had a block with a jumper which I had to remove from the harness first. Fit the switch, plug in the harness and life is good. If you want control of the CDL when in low range then do the pin7 mod.
So, since we're on the topic, I'm unsure if mines already had the 7-pin mod done. So, if I put it in low and don't push the CLD switch, the ABS and diff lock lights will come on if it HASN'T been done, correct?
thanks to all for reaching out to help, but indeed, the actual process of doing the switch add-on has been greatly covered...My interest is in the history of why this particular (and a great one) is included in the vehicle but sort of unknown and that it's just a matter of adding a switch to make it active...what was Toyota thinking? I would have thought it would be featured and trumpeted in their sales materials etc...that's what I was curious about...it amazes me that it is such a simple thing and just lays there dormant until one hears about it and for th price of a simple electrical switch, it's available to all (apparently)...in my previous 4x4 experiences (Broncos, Blazers and mostly in Land Rover Defenders) it usually takes lots of money and wrenching to add something like this...thus, my amazed curiosity about the thinking behind Toyota's decision to include it, but not make a big deal out of it...
I think you are over thinking this CDL configuration trying to make something out of nothing. Toyota had many different configurations over the years of engines, transmissions, transfer cases and other vehicle options across the world, For the most part they all shared common wiring harnesses. You will find many unused connectors in the US models that may or may not be documented in the FSM. Some of those that come to mind are the connectors for seat heaters, center console frig, rear air conditioner and connectors that exist when barn doors are installed versus rear hatch/tailgate.
If all the sensor switches, actuators, etc. are working properly and all other OEM wiring is in place, connected and working properly then that would be a true statement. To be certain it would not be that difficult to pull the driver's side kick panel and check the wiring harness going into transmission control module. In doing so you would learn a few other things going through that exercise.
My opinion in looking at the history of the CDL Switch would probably be shared by others as well. The first couple years of the 80 series it was included because there was no viscous coupler (limited-slip) in the center differential. To get full traction in 4HI, you needed to be able to lock the axles together. On '93 and newer, these vehicles became even more luxury-oriented while retaining all the elements of a highly functional full-time 4WD, and the limited-slip center diff made this possible without driver intervention. Since the CDL would still lock when shifted to 4LO, all the wiring remained, and Toyota left the option for manual control in place (i.e. switch connector).
YES.
AFTER the PIN 7 mod is done, the only way to turn off ABS and engage the engage the CDL would be with the switch installed. The lights are only displayed if the sensor on the center diff is functioning. On mine it was not working and had to be replaced.
ToyotaDon thank you! I am a history nerd and evolution of systems and "why" always fascinates me and sometimes can inform one of what to expect from those producers and systems in the future...very cool and very much appreciated
There are more examples of this with Toyota, including the popular ATRAC mod for the FJ Cruiser. If you didn't purchase it new with that option, all you had to do was install the switch.
I could use a switch, is it the later or earlier version?
The one o have is for '94, older. I also have a hazard switch which is the same size as the newer cdl switch it would just need to be labeled if you want.
