Is there an original "adding a CDL switch" thread?
Here is what the jumper looks like along with the switches.
I just finished cdl switch install. When would you need to be unlocked in low? 7pin not done yet.
So to engage in Hi, do you come to a stop and go into Neutral? Or can you cdl switch in gear, on the fly?
CDL can be switched on/off on the fly as long as you are not spinning the wheels (where the speed of the front and rear axles are different).
As far as when to unlock in low, there are several threads addressing this. Search will provide a lot of good information.
A steep boat launch comes to mind...
i unlock my center diff when traversing tight switchbacks, it makes maneuvering a bit easier...
Ummm...my '93 with factory locks and CDL switch...the ABS light will come on anytime the CDL is engaged.
Not sure about that 7-pin mod (is it only for non-OEM CDL switch installs?)
The CDL switch engages the CDL anytime the switch is pressed - in hi or low. And the ABS light illuminates accordingly.
It IS NOT automatic when shifting in to low, at least not on mine. I feel this gives total control over the 4x4 system like few other vehicles. I also like how it gives me full lock in high if I want it, unlike any other vehicle in the US market.
This is normal, right? I'm not experiencing the PO's creative wiring diagnostics or anything, am I?
Thanks. Is this situation referring to having triple locks, and unlocking center, or open axles?
It applies to both... it really comes down to traction. If there enough traction the diff lock(center or axle) doesn’t need to be locked. Using the boat launch(paved) as the example, you wouldn’t want the center(or axles) locked as there is no worry of wheel slip, but the extra torque from low range would be desired...
As for the switchback example, if I need the traction I keep the center diff locked. Attempting a switch back with the axle lockers on would be difficult, but every situation is different... never say never!
The question isn't "when to have it unlocked" but rather "when do you need it locked". That's why I like the CDL switch and pin 7 mod. You really don't need the center locked most of the time you're rolling in 4lo. Having the center locked makes tight turns annoying, especially if you ever do switchbacks that require a 3 point turn to get around. I only lock mine for the duration it needs to be going over an obstacle.
You can lock the center on the fly. I do it on a 20% grade to my house if it's really snowy/icy just for added insurance that my wheels don't slip and I won't loose all my momentum (my friend had this happen on the same hill and he started sliding backwards -- not good).
As to why the switch isn’t already there - it was likely due to a lack of faith that the typical US buyer (or buyer’s kiddo) wouldn’t activate it at the wrong time. 91-92 had it. I’ve always assumed it was dropped under the protocol of lessons learned.
Someone added the cdl and pulled pin 7 wire or cut it.
Or the 4 Low Position sensor/switch is not functional.
In his case he is pushing the cdl in low or high and it is functioning according to his post, therefore someone also did the pin 7 along with adding the cdl
Even with the the CDL switch added still doesn't mean the pin 7 mod has been done. If the 4 Low position switch is nonfunctional you get the same result. The only difference would be with the pin 7 mod the shift points in low range would be bumped up. No pin 7 mod then the shift points would not change from high to low.
Fascinating. FWIW, the CDL switch has the same 'patina' as all the other dash switches.
But to
Are you saying the US '93 never came with the CDL switch? I don't know either way, but let me also mention I have 3 locks with cloth seats and no sunroof. And I'm certain it is all period correct, or at least period equal (everything shows the same age).
When you say 'shift points are bumped up', are you referring to the rpm's at which the gears change in high or low? And as such, I'm assuming the shift points would be lower in low range than in high range?
I can tell you low 1-2 shift happens around 2k rpm. It's right for some terrain, not so much for others. Don't get going fast enough often enough to know other shift points in low. Hi points are what they are, dependent upon the 'Power' switch position.
Are you saying the US '93 never came with the CDL switch? Only the US 91-92 models came standard with the CDL Dash Switch, any other years the switch has been added.
I don't know either way, but let me also mention I have 3 locks with cloth seats and no sunroof. And I'm certain it is all period correct, or at least period equal (everything shows the same age). Yes, those combinations were all available configurations. In addition other configurations included leather, a two compartment center console. If you have ABS, then you most likely also have rear full floating axle, rear disc brakes and other items.
When you say 'shift points are bumped up', are you referring to the rpm's at which the gears change in high or low? And as such, I'm assuming the shift points would be lower in low range than in high range? Yes, the RPM where gears change. In stock form the shift points are at a higher RPM when in low range, similar to when you push the ECT button. Seems to b a bit bassackwards qat first thought like you guessed. Higher shifts points can be good or bad depending on your needs or preferences. That is why you may not want to do the Pin 7 mod instead just unplug the 4 Low Position connector on the transfer case. Easier than digging into the wiring behind the kick panel to check if the pin 7 mod has been done you can quickly disconnect the connection on the transfer case to see if shift points change. Second test would be to pull the plug and short the two pins together on the harness. The second test should give you the high shift points for sure.
Exact RPM's on shifting all depend on how hard you are trying to accelerate. Like you say sometimes good, sometimes not preferred when it snaps your head back or the passenger's heads back when it shifts.
Mine shifts at 2k, regardless. How much my head snaps depends on how fast I'm accelerating when it shifts. lol But I'll play with the ECT button and see if that changes anything.
In that case you might want to experiment with the transfer case wiring. If the 4 Low Position is nonfunctional the the shift points won't change either way. You can also verify the sensor switch testing its function with a meter.
