Is it worth it?
Charlotte NC
I bought a cruiser last week (fj40) and it has the stock 3 on the tree.
I have a 4 speed tranny and T-case out of a '75 Fj40 that I could put in there. The 3 speed works fine, but do you think putting in the 4 speed would be worth it? How hard would it be to install it, and would I have to get new driveshafts made? Im sure somebody has done this...so help me out. Also...do you think it would help resale value?
Is the rest of the truck fairly stock? If so keep the three on the tree. Old school three speeds rock.
Just my two cents.
mdjohnsen said:
What is 3 on the tree?
come on man, ok a 3 on tree is a column shift. That means instead of the shifter sticking out of the ground it is sticking out of the column. It's like mini vans, or ford f150s, you see how you go from park to drive on an auto in a mini van, well a three on tree is similar to that except it is a manual. I hope that makes sense.
personally I would swap and think that swapping to a floor shift would help the resell value, unless the buyer is a teq purist, which is unlikely unless you are planning on doing a perfect restoration....
FWIW, I have a 1970 FJ55 project and am switching to a floor shift, I will however be trying to keep the vaccuum actuated 4wd lever though, those are cool! :)
Noah
3 speed
I would keep it a 3 speed on the column. It's been years since I have driven anything with 3 on the tree.
4 speed might be nicer/user friendly.
JR
Since you have a 4 speed in your 1975 and the 3 speed as well in the new truck, you know how differently they drive. I really think a column shift is fun, and if you have a bench seat the column makes the middle of it a lot more useful.
Also, you can't put in one of these cup holder thingies with a floor shift.
I love my 3 on the tree's but it all depends on your use of the 40, if no bigger than 33" tires(like a 33x9.5) keep the 3 speed, if bigger go 4 speed, if wheeling alot, go 4 speed, if just cruising around town, say 3 speed.
remember that the 3spd has no synchro in 1st either...so you grind it A LOT until you get used to it...
malphrus
well...john, if you don't end up usin that 4spd+xfercase, i might be interested in it
malphrus
... so you know what most here would do w/ it.. do what you want to do. Sounds like you had it all planned to trade it out but felt "guilty" by changing something.
Don't feel bad or worry about resale etc, etc. etc... Do what you want and how you like it.
If you like the column, 50,000 rpm at 45 mph then keep it! LOL.. j/k
It's all good bud... it's all good.
Good luck
Bx
