So i opened up my charcoal canister for my 1994. The FSM states canister that we should be able to blow low pressure air through the tank pipe. This is logical because you want the tank to vent excess pressure. But here is the think. When i open it up there is a valve under the tank pipe that consists of a steel ball and spring. Funny think is mine moves freely and clearly the spring pushes it into a position that PREVENTS pressure from the tank to enter canister. It is configured that the more pressure is applied to tank pipe the better it seal and prevents pressure from passing. Just really odd.
On a side note. The other line going to the manifold has NO valve assembly at all limiting air flow. That also aounds backwards to FSM. I am thinking of digging through my old carbon and seeing if there is a spring or other valve parts that fell out of the lid assembly.
