Sent you a PM.Can you send me an email with what you are trying to buy so that I can look into this for you?
That worked! @Ironman4x4America no need to follow up.SPRING25
Awesome!That worked! @Ironman4x4America no need to follow up.
Anyone rocking Foam Cell Pros and OME 864 springs? I bought the 2” constant load kit from Metal Tech back in Nov of 2018. The rear was initially pretty high but it has settled more than I was expecting. I sold my RTT and am going to be going drawers and rear bumper. I don’t have faith in my current rear springs.
Would love to hear what combos you got for some weight in the rear.
I didn’t mention it, but I also plan on towing a 16’ aluminum fishing boat as well. Sounds like there shouldn’t be an issue with the 864s but some may prefer 863sI run that combo.
With drawers full of gear and rear bumper and swing outs it still sits a bit high in the back. While the extra departure height helps with clearing some obstacles maybe the 863 would be better option if you don’t have constant 600+ lbs behind the rear axle.
wngrog, Do you have 6 (SIX!) Land Cruisers currently in your stable, or one at a time?100% still love mine.
45, 60, 80, 100, 100, 200wngrog, Do you have 6 (SIX!) Land Cruisers currently in your stable, or one at a time?
They are same as an FJ60Nolen, what part numbers are the FCP’s you run on the pigs? Thx
I've got a set of the TOY013B-100 which are their 0-440lbs springs that I'll try first and will see how I like the ride when I get the rear bumper and spare back there. Rear springs are trivial to change If I need a change down the road.Now make sure you put some nice soft coils in the back to not ruin the ride. I don’t like any of the Ironman coils. All are too tall and too harsh.
OME 865/866 are my go to
I got through 15 pages and only saw two sprinkles on this topic. Anyone use these shocks on the front with no additional front weight?They will be fine. They are designed for lifted trucks and they possibly could bottom out.
Pick up a set of used OME rear springs (got some $125 OME 860)
Adjust torsion bars up about 1.5" and add tires later.
Did you change the springsI got through 15 pages and only saw two sprinkles on this topic. Anyone use these shocks on the front with no additional front weight?
My cruiser has fcps on all four corners with 2866 coils. I have sliders and about 250 lbs of constant load in the rear. My rear center hub to fender is 22” and the front is 21”. The ride up front is complete ass. Crazy bounce off a small bump. The suspension shop advised that ar the current front height the shocks are too long. All other suspension components in good order.
Anyone else experience this? Is everyone else higher than 21”
Rears are 2866 which have been on the vehicle since I swapped my suspension with iron man’s on all four corners about 25k miles ago. Only thing I’ve touched recently on suspension is replaced rear foam cell (non pro) with prosDid you change the springs
Stock torsion bars or IM TB?I got through 15 pages and only saw two sprinkles on this topic. Anyone use these shocks on the front with no additional front weight?
Stock torsion bars.Stock torsion bars or IM TB?
The shocks are 0”-2” lift and at 21” hub to fender in Front- you are with in the designed range of shock travel. But if you have stock torsion bars, that’s too much lift on stock TB and could be the reason for more jounce.
