Intermittent electrical shutdown
my 97 lx has a strange evolving behaviour, a little back story.
Some ten yrs ago I took the truck to a local shop to have the starter contacts done ( mistake) upon disconnecting the battery the alarm went off and in his frustration the mechanic randomly pulled wires until the alarm stopped. Over the next 6 months I had random door locking / unlocking and occasionally no starts. I pulled the starter myself and cleaned the contacts carefully and the truck has always ran well with the occasional no start.
Fast forward to the spring and I had a significant exhaust failure and took my time over the summer with an exhaust replacement and some general pm. Nothing electrical was touched.
Now I’m having complete intermittent electrical shutdown, truck will start and run perfectly and then while driving it just shuts off as tho the plug was pulled. Truck has mostly started right up but today it also acted as though it would not get fuel for a moment. Got it running and home.
My thoughts . A short, causing complete momentary shutdown?
The half disconnected alarm causing problems?
Ecu?
Thoughts please, and if anyone can direct me to the best alarm removal thread that would be great, andvor a trouble shoot list for me, I have searched and not quite found what I need
Cheers peter
I think there is a connector on the last pillar in the cargo area, maybe drivers side, that tends to go bad, but usually just affects the lighting circuits.
Did you disconnect the ground straps to get to the exhaust?
Try cleaning the coil/igniter cage hold down bolts, that will cause no starts. The 100 has a seperate wire that grounds to the wheelwell and the block.
starter contacts gone bad ?
Is there a pattern when it shuts off?
Under load, at certain speed, etc?
No pattern at this time, I have a scan gauge and it seems the scan gauge and radio go and then a few seconds later all electrical, and no cel when it goes dark, and no codes are stored
I did just replace the entire exhaust, I’m going to check the rear most ground to make sure I didn’t manage to hit it ( I don’t think so) when I installed the new magniflow ypipe
Not much more than a guess but i was having similar shut off while driving issues and was mostly initiated with throttle input (like a pass)
Cutoff on highway eith no prior indication and could 7/10 throw into nuetral and start up again and then hit drive)
Believe my problem to be part of the COR (circuit opening relay) path. Installed a jumper wire to get around problems (new cor relay didnt fix) and then replaced dizzy and maf units after reading here they were invovled in said circuit and installed new COR and have been good for 2 year plus. (Knocks on wood)
That would likely be way up stream, close to the battery. My first check would be fusible links (FL Main), the quick test is to pull on each one (there are three) should not be able to pull them apart, if one does or stretches, found the problem. The fusible links are the three small wires attached to the positive terminal of the battery, two go to a black box, the other a gray plug.
Going to look at this shortly, and I think we may be onto something, right before these problems started I put a battery charger on, I unbolted both terminals and pushed the pos cable out of the grommet so there was no risk of contact,mi may have damaged something in the process
Ok, started right up, as it has been doing. While running I moved and flexed the pos and neg battery cables and the area around the fusible links, no change in engine performance. I checked all the grounds all appear intact. I did not open the black and grey boxes on the pos cable and check the individual links, should I or was the relatively forcefulness of the manipulation enough?
The relative forcefulness SHOULD do it. However, I am one that like to do the forceful version after I do the get it warm and flick the wire check to see if minor movements affect the wires. Sometimes "yanking' makes them connect through strain, but flicking allows that momentary break in signal.
That said, I would lean toward the alarm if you still have the RS3000 factory alarm.
I bought my truck 6 years ago and have never owned a FOB and have never set the alarm. About 1-1/2 years ago, I went out to pick up dinner, and I came back out to the truck with the parking lights on and non-responsive on the ignition. I tried disarming with the key in the ignition (worked before) and it wouldn't resolve. Fortunately, I had a few small tools in the truck and I opened the door and of course, the alarm started going off (everyone in the parking lot ignores it anyway.....) so i lifted the hood, unhooked the battery cable for about 10 minutes, reattached and drove home.
After dinner, I removed the driver's seat and proceeded to remove the entire alarm system. It took me about 6 hours, but I also did the Pin 7 Mod, Installed a CDL switch, and replaced the steering column seal and rag joint while I had all of that area torn apart. I also reworked the fuse block to accommodate the wiring harness for my Ultragauge, so I could keep the fuse panel cover on the dash.
As far as the alarm it was very straight forward. Start under the driver's seat (remove the seat) and unplug the alarm box. Follow the wiring harness over the the kickplate on the DS floor. Remove the kickplate and pull the harnesses out of the A-pillar. Unplug everything related to the harness for the alarm, and plug in the now loose sections of the original harness back to each other. Work your way through ALL of the wiring until ALL of the Alarm harness is free. BY the time I was done, I had removed my center console, the dash plate around the radio (to remove the alarm indicator and harness), the glove box door (to remove the alarm antenna) and all of the metal dash support and plastic under the steering column.
Since I had all this stuff off is why I did all the other things at the same time. I had already been planning on doing them and had the parts, but the alarm locking me out was the last straw.
If you find any clip connectors or crimp connectors or splice connectors, remove them and clean up the wiring so you don;t have moisture problems with the wiring later on. Fortunately, the only thing I found that I didn't remove was a ground wire connector that grounded the dash to other things. Mine was mostly plug and play. Got it done and it fired right up, runs better and have had NO electrical issues since.
Prior to this, I had what appeared to be alternator issues, battery issues, and ground wire issues. All those issue are gone now!
This is an easy task to remove the alarm. Just follow the wiring path. And search Mud.
Wiring is complex, so clues are important, pay attention to what happens when.
The radio and ECU are powered by the FL Main fusible link, to the white wire circuit. They both share a splice point(E6). From the posted clues, from the battery to that splice point would be the first place to look, with the largest (blue?) fusible link being the most common failure point. Even if there were codes, the power interruption would clear them.
Thanks tools, in the couple instances when I've been driving while this happened I have twice noticed the scan gauge and radio shut off first, I'm going to replace the fusible links regardless and also continue and remove the alarm , will report back as e go
Hey built, I'm chasing this harness and am having trouble with the concept of unclimbed some and red lip the loose fixtures, I've been able to follow most all the wires to various tie in points but am scratching my head a bit , I've now removed the glass break sensor and am still chasing wire. Maybe I'm just not far enough yet
@Bogart, in your opening post you stated that it has stalled more than once and that you somehow got it running again.
What did you do in order to make it start and run after an uncommanded shutdown?
Hi baldi, it always would restart, sometimes it took multiple efforts with the key. Yesterday I completely removed the alarm, it took some time. So far it has started and run without issue since the alarm removal but I’ve only driven it three times for a total of maybe 20 miles since, if it continues to behave over the next week I will start to believe we have resolved the problem
Have you replaced the efi relay? I had a one time event where my 93 would crank and crank with no fire. I tracked is down to a loose fitting ignition fuse at the interior fuse block. Cheap crap fuses from you know where are very thin. But I hinknthat fuse has onkybto do with starting.
I’m sure the problem is something simple.
But I hinknthat fuse has onkybto do with starting. QUOTE]
You must be using a Motorola Z Force Droid based on your seriously f'd up autocorrect. I get the same crap.......
