Intermittent electrical shutdown
Nope, an iPhone 5 that apple is screwing with because I don’t like to do updates. Nonetheless, I should have proof read.
I removed the entire alarm and it ran flawless for a bit, problem is back so I now need to replace the fusible link which is in hand, was trying to find a pic to compare as I think one of the wires on my link is not attached and of course I’m having no luck finding what I need on search
When it turns off, without turning the key, still turned to run, is the CEL on?
Hi tools, I have noticed that when it is in its non running mode I can crank but there is no cel light, when it all works I do have the cel light. I just replaced the fusible links, no change. Could it be an efi relay? Or fuse? Ive just ordered a new Eli relay, will have it tomorrow
If no CEL, then the ECU is in a non-ready state and it will not start.
Either no power to ECU or issue causing non-ready state.
Check your fuse block and the power wires up into the bottoms of the relays. Sometimes they will get hot and melt under there. Out by battery box.
It started and ran normally which it has been doing for a bit, a mechanic friend brought his multimeter and we retested the new fusible link to make sure it did not short, it was fine, we could replicate exactly the scenario with the no start no cel by removing the efi relay, re installed and runs at the moment. I have ordered a new one in case this one is going south. Any other thoughts? Is there anything between the efi and battery we should check? I will remove the fuse block tomorrow and check the wire condition under neath. Anything else?
The wiring/relay thing is much more common on the early models.
When the failure happens, CEL off with the key to run, is there power at the B+ term in the diagnostic box? If not, power is not getting to the ECU, not gona run. One place to check is the single wire (yellow/red stripe) connector (EB1) between the distributor and intake. Have seen that one get corroded, overheated, causing an intermittent connection.
Funny update, started and ran, dies within 10-15 sec. by coincidence I had the door open and pulled it shut, immediately all the lights came back on and it would start, 10-15 sec it dies and all the lights go off ( except the two on the farthest right side of the display) slam the door, and everything comes back on. Close the door gently does not resolve the problem, makes me thing there is something loose, this is the driver door I’m talking about, if the efi is go8ng could the vibration affect it? What would be affected by the shock of a slammed door? Is there anything in the fuse panel in the dash? As that is close to the door? Thoughts?
Help! Started normally , started to drive got about a mile and same problem, has a new Efi relay, haven’t removed the fuse block in the engine bay yet , changing fuses in the interior panel, have checked grounds all appear tight etc. Need some help, haven’t been able to get a multi meter on the b port yet and not sure which wire tools is speaking of regards the distributor to intake, had a look and it may not be obvious to me
Had the same problem, I changed the EFI, fuel pump relay and Fuel Pump resistor and interior fuel pump relay drivers side kick panel. It probably was only one of those but to be safe I replaced all 4. Should be good for another 20+ years.
Did you ever look at the wiring harness back by the EGR valve? Common problems area.
I checked where it enters the ecu, I ran out of light, I rebuilt the h as and hg a couple winters ago, and re wrapped the cable in that area. It will be the first thing I check, I’m not hopeful at the moment and am contemplating lighting it on fire
In order to not totally s problem I have waited a bit to post what appears to have been the problem / solution. As was mentioned in a few threads the ‘grey’ plug adjacent to the distributor which powers the ecu can over time loosen or become corrupt, this ended up being the problem, and the solution was to cut the offending plug out and splice in a section of wire. So far so good with zero repeats of the power loss problem. As a side benefit removing the alarm has also resolved a few other problematic gremlins and the old girl is rumbling along like a champ. Next on the list is some body work, lining the lower half of the truck, a seat refresh and a few other pm itemsMany thanks to all who helped, in particular Kevin who went well above and beyond to help me narrow down the problems
