Intermittent code 26
Now is a good time to replace your faulty injector, if it is indeed broken and have the other 5 cleaned.
they are all getting taken to the injector service shop thursday. Picked up my new gaskets today and I am waiting on the injector connectors to show up. I broke 5 removing everything. my fuel filter is about 6000 miles old, But Ill replace that as well since Im in there.
Damn, this is a painful thread to keep reading. You need to catch a break here somehow and not breaking injector connectors! Sending some good landcruiser karma your way!
Yeah it's been such a damn headache! I'm hoping so! Thank you. I sure need it!!!
I broke a couple if those injector housings. It isn't to hard to depin, #6 is a mild PITA. I will say after I got everything put back together I couldn't believe how much better it runs now. I really think the injector service was a big part of the improvement.
Good Luck! This has been quite the saga.
How did you remove the old clips?
I think it should run really well after this!!! I mean it better!!!
Its the VSV that operates the EGR not the PAIR. Common for it to get plugged with carbon when the EGR modulator fails letting carbon and rotted modulator material to enter the vacuum system
dsc04290-jpg.29431
update:
tested all the vacuum valves and this was the culprit for this issue. it was the only one that did not click and actually had no response when power was applied. So ill be ordering one of these, a new intake tube, and then when I get my injectors back I can button it all back up, adjust the timing and then get it smogged. Jesus what a process this has been. I feel after doing all of this I could be a 80 series pro! Ill post up pics when I get the injector results back.
Eric
Make sure to blow out all the hoses and hard lines in the plenum and get a new EGR modulator before you install the VSV or you will have issues again.
I'e already blown out all the lines and scrubbed the insides of the manifolds. all hoses are new and all lines are clean as a whistle. I have an extra modulator that I may throw in to be safe. Been cleaning everything that I can while I have the parts out. even cleaned the port that goes from the throttle body opening to the EGR port. that was nasty with Carbon stuff that seemed to chip right out.
My injectors are about 2 weeks out from being completed, So I'll have plenty of time to get the other stuff replaced and ready.
I just followed the EWD. It can be tricky sometimes so just have an assortment of picks or small screw drivers.
So I replaced all the injector connectors, had the injectors serviced and put everything back together today. She seems to be running great! No cel. So now I just need to adjust the timing and get it smogged again!
So she finally passed smog!!!
back on the road!!! thanks for all the help guys and gals!!!
If you need wire harness parts like the injector pig tails, I have a 1994 engine harness that I retired near 2 years ago. I think #6 is the only broken one.
I replaced them all with new ones.
Thank you very much though!
Ok, I must have missed school that day. LOL
Ok so WTF?..... truck threw a Cel yesterday. Code 25/26. My timing was off. It was set at 0* btdc. I'm wondering if it was running rich due to that. I set the timing back to 6* and haven't seen it back on. If it comes back on I'll be tempted to drive it off a cliff!
Does 6* add any noticeable liveliness to the seat of the pants feel? I have never tried going above the factory spec of 3*.
Seems like it does. That's about where it was when I bought the rig years ago though.
