I ordered one from Beno on 3/2016 it was 54.00 and only came in black.
I got one in the last 6 months from an online dealer for about that. Will paint with SEM Cordova Brown.
With the headlight washer, it might be a lot easier and cheaper to make a cover for the top of the reservoir that glues to the sides as I think most are only cracked on the top
Everything is possible! At the moment we are setting up the shop and will start doing some samples in coming month. We want to make sure we produce high quality items for you guys.Inner seatbelt receiver sleeves![]()
Color of the bezel will not be an issue. I will bring it up to buddy of mine who is an engineer behind this and we will discuss a possibility of making them aluminum instead.Toyota calls the 'A/C Bezel' an "Instrument Cluster Panel" ... There are various part #s depending on year and color, but there are basically only two variations the 555412-90A01 and 55412-90A02 (81-mid 84, mid-84-87) which probably only differ slightly on mounting points.
So, if one could be made in black, and universal, to fit 81-87 it would be a big item as they have been NLA for quite a while and they're ALL CRACKED !
Yes we can. At the moment we are just starting up so we will be producing items in high demand in order to enable further expansion.Not interior, but carb insulator plate would be nice. Assuming you can 3d print with an appropriately heat resistant polymer.
Toyota calls the 'A/C Bezel' an "Instrument Cluster Panel" ... There are various part #s depending on year and color, but there are basically only two variations the 55412-90A01 and 55412-90A02 (81-mid 84, mid-84-87) which probably only differ slightly on mounting points.
Plastic clips that retain the chrome door weather strip to the doorWell it seems like you guys have voted on first reproduction item. Look out for website and distributors, as well I will post a response on here. We are going to be up and running in coming few months.
Wow, thats great, thanks for the tip gila, will order sime prontoThose clips are still avail
#68211-90K00
