- Thread starter
- #61
I have had one of these harnesses sitting around for over a year. I need to get after it.
Slacker! It actually goes in pretty darn quick.
I would have to say the Slee harness wont help. the only thing you are eliminating(by installing) is the wire run to the passenger headlight, and the original bulb sockets for the headlights. When you say you fiddled with the bulb socket, which bulb? that got it working right. Another question, does the running light and brake light function properly on the right side all the time?
The bulb I messed with was the left brake light bulb. As for the right side, it works properly all of the time.
Just installed today following your write up. Perfect instructions, had it done in under an hour. Thanks again!
I have had one of these harnesses sitting around for over a year. (In the same box as a set of panhard bar adjusters, a TruSpeed, and the speedometer drive o rings) I need to get after it.
I still need to get to this...
What are the differences between the "New" Slee harness and the "Old" one?
Dave
From what I remember reading some of the units were prone to failure. Headlights stop working.
Hmmmm, I wonder, A) When the changes were made, B) If I can easily identify if I have the old or new
If you call Slee they can tell you. It was an intermittent failure due to manufacturing issues on some of the early ones.
I'll go dig it out at lunch today to see how many pins are on the relay.
Can anyone tell if the plugs have been upgraded on the new harnesses, as opposed to the old ones that could encounter corrosion problems? I would like to do this upgrade to boost my HIRs brightness a little more, but like others have expressed, not if reliability takes a hit due to worse-than-oem
I have only ever seen the new ones so I can't really comment other than to say I love this mod and I've had zero issues with it myself.
