- Joined
- Jan 4, 2014
- Threads
- 94
- Messages
- 3,042
- Location
- Little Rock, Arkansas
- Website
- www.facebook.com
I am creating this thread because a couple people requested that I do a write up on 2 products I recently purchased - 10pk Eagle Eye 3W White LED's and a pair of linear LED light strips that are supposedly used for DRL's but I will be using them for addition reverse lights. This will be part 1: the installation and wiring of the Eagle Eye LED's. I only had time to complete those so I have to install the linear strips at a later date as part 2 (I will put that write-up in this same thread once completed). Please bare will me because this is the first 'real' write-up I've done for a personal installation but please feel free to offer helpful advice as I am all ears to new ideas and methods. Some of you may know I have a custom 'New Style' steel bumper courtesy of Mike's magnificent craftsmanship at Bump It Offroad. I mounted the LED's along the side of the bumper closest to the wheel well.
Anyway, enough will the chit-chat and on to the photos of prep measurements and figuring out where I want them to be:
Unfortunately I did not have a step drill bit so I have to go through about 8 different drill bit sizes before I finally reached the diameter I needed. Even broke a carbide bit in the process
Guess a step bit is next on my shopping list. I also got a Q-Tip and coated the inside of those holes with a primer and painter all-in-one offered from Rustoleum which supposedly prevents rust.
Test fitting the LED's to make sure they're nice and snug...they came with a bolt to screw on the back and sandwich the steel plate between the light and nut...
I recently purchased a tube of marine-grade silicone sealant that I used to properly seal my off-brand 20" light bar (I had begun to notice small amounts of moisture build-up on the inside of the lens and figured it'd only get worse over time. Anyway, I used that as a sealant to hold these LED's in place. They are DEFINITELY not going anywhere and even doubled as a form of Loctite.
If I did my math correctly, 10 of these 3W LED's draw 2.5A. With such low amperage I figured that there was no need for a relay so I decided to tap directly into both turn signals so that they will also blink along with the stock indicator lamps (tuns out they actually blink opposite of the stock turn signals - when stocks are on, eagle eyes are off but it doesn't bother me at all. I'm sure that most of you electronics experts will see that I used the same wire or pos(+) and neg(-), but the positive green wire actually has a black strip that runs down it lengthwise but you cant really see it from any of these photos..
To be continued...
To be continued...
