In preparation for doing an OEM subtank install I attempted to pull a few rivnuts using the technique mentioned by Romer via CDAN. I had a lot of difficulty using this technique and imagined if I was under the truck there would have been a lot of explicatives... IIRC Romer mentioned it took him a long time to finally get them to seat. Anyway, I searched the web and found a similar technique which seems easier and prevented slipage of the rivnut even when the ribs on the rivnut were not gripping. Basically, you utilize the same technique ( bolt, nut, washer) but before threading the bolt onto the rivnut you add another nut but larger (eg: 10mm if you are using 8mm rivnuts) and an additional washer. You also want to lubricate the washer on the side facing the 8mm nut. You then use ring spanners for the larger nut and the bolt. You turn the nut in between the bolt and larger nut clockwise. Aside from having to keep the ring spanners from turning it was super quick and seemingly fool proof. I imagine one could use vice grips also.
Here is the link to the website:
http://ourworld.compuserve.com/homepages/oakwood_data/pulling_rivnuts.htm
*** Note I haven't done this on the lx450 yet so I don't know how much room is under there for this contraption on the two low clearance holes but it is a fairly straightforward method of installing rivnuts for other applications as well.
