Installing new CV driveshaft tonight
Ok. I installed the OME lift on my '81. The lift looks great and rides great, but i was having rear-driveshaft vibration from the change in the pinion angle.
So, i had a custom driveshaft shop convert my stock driveshaft to a CV shaft which I will be installing tonight.
The only concern i have is that the new flange is slightly thicker than the old one and I'm not sure if the stock bolts are going to be long enough. Can i pick up longer bolts at a napa store. Anything special I need to know or ask for? Do I need to use locktite?
Thanks :beer:
Here is a pic post lift. I just need to get new tires now!
You should have used a shim or different length shackle to get your ujoint angles right on your stock shaft. Unless your pinion is pointing at your transfercase (which I doubt it is) you are really going to get some vibes now I bet.
To answer your other questions, no you won't find the proper driveshaft bolts at NAPA or anywhere but the Toyota dealer, and yes locktite on the nuts and bolts is a great idea.
X2
CV shaft is not a cure for pinion angle mismatch problems.
It can be the solution for too high of an operating angle, but only if you change the pinion angle so that it is in line with the shaft.
Nomis said:
Looks good, what size meats are you going with?
I'll probably do BFG 33" AT's....once i feel like dropping the cash that is!
I had the same issue and used the same solution. Contrary to what others have posted here, I have no vibration under any condition. The reason I took the CV route is that the owner of the differential shop said it was the best solution. And no, he did not make a dime off the conversion. It was done by a drive shaft company in Tucson. See photos. The photo with the skid plate is the only one I currently have of the pinion.
hmmm. My driveline was off between 2 and 3* and I was getting alot of vibes at above 45 mph with my cv.... Yours looks alot shorter than mine though. Might have something to do with it?
-Dustin
BSEVANS.....
What size plate are you using for your skid plate. That stuff looks BEEFY....
73fj55 said:
BSEVANS.....
3/8"
....who made the skidplate? screw the cvjoint! wow, such 3/8!
When I needed a CV for my rear shaft I used the front shaft out of a BJ60.
It bolted right up to my SM420/3 spd t-case without a problem. And It was cheap.
I just shimmed up the rear diff to point at the output on the t-case and I have no vibrations at all. I think the shims were 3 degrees.
Please elaborate on the construction of your rear drive shaft....
Are those mini-truck pieces or Spicer? they look like 1310 spicer...
Did your drive shaft shop find a piece to match the parking brake drum bolt pattern or did you modify the drum?
Thanks!
Poser's got a good point, Looks like 1310 stuff.. Toy CV's are supposidly Strong as hell..
To answer the first Question, Do not use just any bolts for the Driveshaft.. Use only Toyota OEM Bolts.. The local Pick and Pull Junkyard should have what you need..
Thanks!
Yes, it is a Spicer and yes, the shop did have a piece to match the brake drum. They asked if I wanted to wait till they could get the mini-truck pieces in. I wanted to wheel it that weekend. That DS has been in for over 3 years and I have had no issues from 5mph to 80mph in or out of the throttle. You will have to educate me on the differences in strength and any pros/cons.
I was incorrect; the drive shaft shop wanted to also put a 1310 Spicer U-Joint at the pinion end but did not have one with a flange that would marry to the factory pinion flange. They also did not have a replacement flange for the pinion shaft that would mate to the standard 1310 Flange and said it would take 1-2 weeks. So they flipped the drive shaft and installed the Spicer 1310 CV the way you see it with the flange to mate to the brake drum.
