H7what are the bulb sizes for these depo lights?
The grill is easy to pull as well, just a couple clips on mine at least.FedEx should be dropping mine off today.
The OEM headlights easy to come out, right? Don't have to pull the grill i hope.![]()
Yes, pull the grille, but it is very easy. 3 Philips screws and two clips.FedEx should be dropping mine off today.
Both bulbs are H7 and yes, they bolt onto a 2001.what are the bulb sizes for these depo lights?
oh do these bolt on to a 2001?
I agree with this. I had an accident after my initial install. Once those corner lamps are replaced by the one piece unit you'll be able to field strip the front end down in a couple minutes if you needed too.Yes, you do have to pull the grill, but as stated above it is 3 screws and 2 clips (no big deal)
The biggest pain we had was removing the corner/side lamps that have 1 screw and a clip that holds them to the OEM headlight.
(I'm not CharlieS, but here's a sample from my son's truck)
Depo Low Beam
Depo Low Beam + ARB Fogs
Depo High Beam
Offroad LED lights:
What bulbs are you using ?
Whatever came with the Depos
I think that's probably the case, I'm quite happy with my Depo's, and I'm only using the bulbs that came with them. I'm interested to see your projector swap though...Sounds like my problems may be helped by better aiming. I upgraded to the Silverstar ultras in the low beam.
I was frustrated too, but I got them to fit after some dremeling. I realized after though that I did not need to dremel at all. The female edge of the Depo plug was getting hung up on the truck side. Give it another go.My plugs don't fit at all. I got frustrated and stopped for tonight. I'll mess around with it tomorrow.
