OK... Since we are all full of Turkey and too tired to care or guess...
Here’s the idea...
First, it’s FREE surface space.
-When living out of the truck, the tailgate surface is prime real estate for everything from cooking, preparing, tooling, etc. So after often trying to set items on my water cans...I thought of a super convenient “mini table” that will always be available no matter what.
Great for hot food...hot coffee pots...etc. with no interfer
Hot water!
-When you use a Kariba, it heats the water quickly...but having to monopolize the tailgate while heating sucks. Plus, it’s dangerous as it pipes super-heat up and into the open hatch. Tables can be used, but who wants to monopolize a table while camping, when you could be using it for other stuff.
So... thst’s Where the weird items on top come in.
The two black things are actually strong magnetic firearm mounts...repurposed to instantly and strongly secure the Kariba heater/stove while heating water. This takes it out of any tip-over danger...gets it out of the way...and allows easy access to the water cans it heats, pumps from, etc.
These magnets are SUPER strong with rubber housing and screwed to my table. The Katiba isn’t going anywhere until you want it to.
I trimmed the Kariba’s rubber feet at a slight angle to create closer proximity to the magnets. If I want stronger attachment, I can trim more...but the magnets could easily be TOO strong. So it’s nice to be able to fine tune the pull in this way.
Once the water is hot?
Now I’ve got a great little surface that’s sturdy and easy reach, but out of the way of drawers, etc.
Edit: The table is off-set toward the one side purposely. This is to clear my propane tank, and also so that it extends as much usable surface out from behind the ladder as possible. Since the Kariba is secure at the very edge of the other side, this turns into a great space even when the heater is in use.
Anyway... Super happy with this little idea.
