Inner axle seal question/help
PHX AZ
I bought the harbor frieght race/seal installing kit, and well it workerd great for installing the new races:) but when I tried to install the inner axle seal it messed it up bad:bang:. I tried 2 different seal installer sizes, the only 2 in the kit that looked like they would work and it hosed both of my brand new seals so im off to the stealership tomorrow for 2 new ones. Can anybody who has this kit or used the kit chime in on this. What size end did you use to install the inner axle seal?
Thanks for any and all help
Robbie,
I think most here use a socket to push that seal in. Just pick one that obviously fits well and tap it in using a socket extension. Obviously one of the key elements is to not disturb that tiny spring. Be sure if you've dislodged one in your two attempts that you get it out of there - it's spring steel and very hard metal that will be tough on things.
DougM
I read on here that some have used the harbor freight kit, thought that would work best but guess not. I didnt really have a problem with the spring, though I do know what your talking about that spring can be a pita. Maybe im just hitting the seal installer to hard with my hammer. Problem I am/was having is that the seal installer would bend or deform the metal on the out side. I should have just used a large socket. Dumb me. Oh well I will see how it goes tomorrow with the new seals and a socket.
I have the same kit. The beveled side works great for races but will destroy seals.....flip it over and use the flat side for your seals or just use a socket.
Here's what I use:
My son made this for me on his lathe.
We actually were making them for awhile, but they were taking over an hour each to make, plus the cost of the solid maple, and the wear & tear on his turning chisels (hard maple dulls them quickly)... it was hard to justify charging more than about $20 each, so it wasn't worth it. There's probably a better design that could be easier/faster to make and use less wood, but he just lost interest.
KLF: could you post the measurements of the wooden tool?
I'll have to look for my notes with the dims. 80-series are a tiny bit larger than mini-trucks and Cruisers prior to the 80 (62, 60, 40, etc). If I can't find my notes, I have one of each, I'll just measure what I have.
/HIJACK
Is there another seal in the driver side of the axle? When I had the birf out the other day I noticed there is a seal inside the tube just laying there, I am going to pry it out once I get the axle seal out, before I put in the new one? What purpose did it serve?
/END HIJACK
The OD of the seal is ~50mm, the ID is ~33mm, so a piece of ~2" stock turned down to ~33mm, 1.3" for ~3/8" from the end would work.
/HIJACK
/END HIJACK
There is a sheet metal ring pressed into the long side of the housing, it's purpose is to aid in axle installation, maybe that is what your seeing?
No. It's a seal. For sure. Complete with the little spring and everything. I took a pic of it but it's not very clear.
D
I just used a 2x4. But I had the marlin seals so they are easier to install.
