Impossible vibration
Would posting my pinion flange angles tell you anything?
Bring me up to spee on the exact lift set up you have. Yes, post your angles. Are you sure no vibration is coming from the rear shaft?
I double checked the knuckles and the grease level seems good.
My lift setup:
OME springs and shocks. 851 front (med) and 860 rear (med)
OME yellow castor bushings
30mm MAF front spacers
Fender lips sit an even 38" high front and rear
ARB up front, no winch
I took my Tatton front shaft out tonight and all vibrations went away completely...
I also measured the flange angles: From passenger side view*
T.Case- 2.95° \ / 8.70° - pinion flange
(slash is angle of flange from pass view)
So what is that, a 11.65° difference? I'm guessing thats bad...
Which leads me to think I have two options:
1. Add more castor correction. Are plates the only option?
2. Remove 30mm spacers and put stock DS back in. Which means I put 80 miles on a brand new Tatton DC shaft for no reason...
All I know is that you want no angle on the front Ujoint when you run a DC shaft. How much lift is that set up giving you in front? There should be no reason to remove the spacer or Tatton shaft once the castor is adjusted so the front shaft runs a straight line directly inline with the pinion shaft.
what is the caster? Need an actual number. What is pinion angle at?
I don't see you saying you have taken the DS to a driveline shop. Do that, find out if it is balanced right and if not have them balance them. Also need to check for runout on the flanges. If that is all good and you still have it, check for runout on the pinion flanges.
Spindles can get bent, unlikely but possible. I had this in an old truck, not an 80 but once I replaced the spindle, the mystery vibe was gone.
Cheers
Wow. That is an impressive list of work/parts. Simple stuff first here:
Have you pulled front shaft, locked center diff, and driven it?
With 2.5" lift plus 30mm spacer, you're in the realm of needing more caster beyond the ome bushings. Eithet way, this may lead to a new front driveshaft w double cardan joint.
Agree the spacer really might of just put it at enough to make this problem
My lift setup:
For some reason I missed this post last time around.
Your prob is your front shaft, if you remove it and vibes are gone that is it, 100%. A DC shaft can operate at a variety of different angles, that is why it is nice compared to a non-DC shaft. A non-DC shaft is way way more picky in terms of angles it runs at and no vibes, it can literally be down to 1-2* for it to operate with zero vibes. I don't know what a "Tatton" shaft is but by what your pinion angles are at you need a DC front shaft. You say it is new but still, I don't know wtf a Tatton shaft is. Was it balanced? If not, have it balanced and checked for runout. Put it back in and test, still got vibes, check for runout on pinion and t-case flanges. You might be surprised that this can cause vibes.
#2: here is the deal with caster, it won't cause the vibes you describe, it will cause wander and drift at speed on the road. On top of this if your panhard and drag link are not at the same angle or plane you get bump steer. That is it for caster. Vibes can come from some things in the front end but not caster. Like I say it is in your front shaft. Yes there are other ways to deal with caster but 99% of people won't or can't or don't wanna do it. It requires changing the steering (unless you only need 2-3*) to conventional cross over and then doing a cut and turn on the axle's knuckles. Not a task/mod for your average 80 owner. Plates and bushing plus knuckle cap bearings are the only choice besides this. What is your caster at? Put a digital level ($10@hardware store) on top of the knuckle cap and get a reading, align it with the frame rail or it won't be accurate. You want minimum (in my opinion) 2.5* on up to 5* or so max. Getting an alignment will also give you a read out on paper which you can then compare to your own readings and go from there with bushings, plates, bearings or whatever to get it within good specs.
25.4mm is 1" so your spacer is giving you 1+" more lift up front, I am sure this is to level the truck out and eliminate "stink bug". This will increase your caster being out, moreso than whatever is stated online for the 851 sprigs. I have found the basic rule of 1" = 1* is way off. It is a percentage actually, the more you lift the more it increases. I have had 3-5" roughly of lift on the front end of my 80 with different springs and even spacers, in the end I was about 4" and I set caster at 4.5*, it was perfect and I couldn't have asked for better.
Oh ya forgot, did you make sure to install the front "Tatton" shaft so that the splines line up for how it was balanced? When a drive shaft is balanced it is done with the splines and u-joints at a specific setting, usually it gets marked with paint or punches to note this alignment. If you install it any other way than how it was balanced it will give you vibes.
Cheers
A Tatton shaft IS aDC haft. He may need to go back to a stock shaft if the Tatton does not fit straight enough at the differential end. Should be less that 2degrees from dead straight for a DC shaft.
At what point does rear suspension lift cause driveline problems there? The lower arms being longer than the uppers cause the pinion to turn down with droop, correct?
I have the same problem. OME mediums, 30mm front spacers, and 175# winch bumper. I put in a DC front shaft build from a Tacoma rear shaft, re-tubed and balanced by a driveshaft shop that has done several other shafts for me. Vibes were way better but still present, and slightly different. Put new Matsuba joints in the rear shaft, no change. That's where I'm at and I haven't had time to work on it any more. I DD my 80 and it does get on my nerves. My pinion/DS angle is <1 deg., don't remember what the DS/t-case angle is. I'm wondering about the condition of the front output shaft bearing with 228k on the clock.
I'm in the exact same boat. Same DC Tatton shaft after my rebuilt OEM shaft angle was off by 5 degrees. I have a 50mm TJM heavy lift and Icon shocks. New bushings all around and caster plates. No wandering but that damn vibe is ALWAYS there. Current DC shaft angle is 1.5 degrees off ideal of 0 degrees. Fought this damn issue for 2 months straight. Saving up for a part time kit to keep front axle free wheeling at speed and only engaged at low speed. Think old school with locking hubs. In the meantime I pull the front shaft until it's wheeling time.
If you find another solution I'd love to hear it.
TJM 50mm springs here, rig very light (only a rear 4x4 labs bumper, no swingouts, no spare, no sliders, no drawers, no 2nd/3rd seats).. front shaft OUT, CDL engaged, rear shaft rebuilt with OEM joints.. vibe still present. Measure about 7" from axle tube to bump stop. Stock ride height is approx 4", so being as light as my rig is it is lifted about 3" right now.
Threw my spare tire and 3-80# sacks of cement in back, the rear dropped about an inch. Vibe still there but barely.. it is significantly reduced.
When I get a chance I'll be checking rear t-case and pinion angles and consider some home-brew upper link adjusters.
from personal experience. It took a while to finally see, however, the growl you're hearing is almost definitely the pinion yoke on your rear diff. The angle is such that upon decel and accel its rotates into a binding position but just barely. It is due to pinion deflection. If you closely inspect the pinion flange side of the rear driveline you will likely find shiny spots. I chased this issue around myself, it turned out that the vibes were from my factory front driveline being too far out...custom tundra/80 DC fixed that, however it still had a slight vibe and growl. Had to modify my rear control arms to adjust the pinion back into proper operating angles to fix it all.
I'm not sure if the OP is experiencing this but I did and had the rear diff overhauled along with rotating the pinion using Metal Tech adjustable lower control arms. Rebuilt the rear OEM shaft with OEM u joints and balancing too. No more growl in the rear but definitely still a vibe in the front.
Alright gents, sorry for the week off, had foot surgery last week.
Anyways, as I stated I bought a new DC front shaft from CJ Tatton on ebay and installed it. Very nice piece and balanced up to 100mph per Tatton, so I doubt it is out of balance. The vibes i had been experiencing changed, but did not go away. My rig is fairly light (removed jump seats, running boards, roof rack, and pair/egr system). With that being said i figured I have considerably higher lift than the 2.5" and 30mm MAF would suggest, probably over 4" but cannot be certain as I never measured before I installed the lift. The stock springs were totally shot after 205k miles...
So last night I hobbled around the garage on one foot and installed the MetalTech caster correction plates I bought last weekend, along with cutting out the yellow bushings and going back to new Toyota rubber. The wandering/darting on the highway has completely disappeared and it drives straight and true. However, the vibes changed in to more of a rumble/growl, but still shakes the truck at highway speeds. Instead of vibrating in a certain window of speed as before (55-70mph), it slowly builds now as I go faster. I have not gone faster than 60 with the plates installed, so I dont know if it goes away at some higher speed and I wont push it to find out. Today I reset my toe-in to 1/8" after the addition of the plates, and double checked all knuckle/suspension/shaft torque settings. I added about 10 squirts of grease in to each knuckle to be sure. I also changed the engine oil to rule out rough engine feel. No change, still get the growl/vibes.
In a few minutes I will take a pic of the pinion angle to DC shaft and post it to get your take on it. I'll put my digital guage on the knuckle cap and post it as well.
What else do you want to see?
What is flange run-out? How do I check it?
Will be back in a few...
Ok I put the gauge on the knuckle cap and the best range I could get was between 5.7 and 6.3 degrees and feel good about the numbers.
As far as the diff pinion, it looks as though it may point an inch or two BELOW the t.case flange. Maybe I now have too much caster correction? Maybe I need MORE lift... heh
I went ahead and put the stock DS back on after I took this pic, so we'll see how it feels in the morning on the way to work. This pic makes me think I now have too much caster correction for my lift size. I really wish I could know exactly how much lift I ended up gaining over stock, it seems it would answer some questions.
Thursday I am going to go to an alignment shop to get all the measurements and I will post them.
What do you think?
Oh, and as far as the flanges, they feel like they have a lot of play with the shaft disconnected, but I have no reference to know for sure... What is flange run-out and how is that checkdd?
I wouldn't mind having to add more lift, but I really hope my t.case or front diff arent going bad and causing the vibes/growls...
I don't know if this is the proper way to check, but I also unbolted both front brake calipers to check how hard it was to turn the hub. Using a digital fish scale, it took 9.6 lbs of force to turn the hub using the lug stud as a connection point.
Does that tell you anything? I just wanted to be sure the preload felt right.
One last thing, I have 100 series pads up front, and they are an extremely tight fit with zero wiggle room. They pretty much stay in contact with the brake disc at all times. Other than crap gas mileage, could those be causing any vibes or growls? At least until they wear down a little anyways...
On the way to work today the stock shaft buzzed and vibrated, but not as much as the DC shaft did yesterday. The stocker shook a bit at 35mph, but lessened after that but never went away. It also did the buzzing/grinding thing with cruise control on.
So how can both vibrate, while being smooth and quiet with no front shaft installed?
To recap, as of today with the addition of new parts the past few months:
3.7" - 4.2"ish lift height that sits perfectly level. Best guess, never measured before the lift.
OME mediums f&r, OME steering dampener
30mm spacers up front
MT caster plates
ARB front bumper, no winch yet, stock rear
Front knuckle/axle rebuild, Terrain Tamer kit with Timken wheel and trunion bearings, OEM hub and knuckle studs
TR and draglink ends, OEM
ALL F&R suspension bushings, everything, every single one, OEM
Sway bar links and bushings F&R, OEM
All new U-Joints, MOOG on stock shaft
Tatton DC front shaft, brand new
Cleaned and greased both shafts f&r stock
Drained and filled both difss and t.case
Transmission mount, OEM
Pass side engine mount (havent got to driver side yet) OEM
Rotated tires (285 BFG AT)
Set toe-in to 1/8" by tapemeasure method
Roughly 5.7- 6.3° of caster using a digital gauge on the knuckles caps.
I now have vibrations and noise with both types of shafts in, but no noise or vibes without a shaft.
I'm stumped...
